[3.6.0-beta.4] H parameter in new M558.3 does nothing
I had the chance to test the new touch mode for analog Z probes. After a little trial and error, I got it working reliably enough. Unfortunately, the H parameter for Nozzle height to be assumed when touch is detected doesn't do anything in my case. I started with an H-parameter of zero until I got the probe triggering repeatably. When doing an G30 the nozzle height is alsways about 0.3mm too low no matter what H-parameter I use.
@MaxGyver thanks for reporting this. I confirm it is a bug, which will be fixed in the next build. Meanwhile I suggest you use a G92 Zxx command to adjust the height.
