WiFi issues with 3.5.4
@droftarts said in WiFi issues with 3.5.4:
@fcwilt it would be good to work out why it disconnects for you. I’ll ask @dc42 what information he needs to troubleshoot, if you’re willing to give it another go. Otherwise you’re going to be stuck on 3.4, because as far as we’re concerned, the issue is fixed.
I have a couple of other Duet 3 boards I could setup on the bench IF testing without actually being able to print would prove anything.
There could still be connected steppers, temp sensors, etc - just not assembled into a working printer.
I had a bit of time so I setup a Mini 5+ on my bench - updated to 3.5.4.
It has no other hardware - just a minimal config.g.
I also include creating all of the global variables I normal use to see if that was part of the problem.
So far it is staying connected without issues.
