    plugin.json any way to support multiple dsf / dwc versions?
    Plugins for DWC and DSF
    • stuartofmtundefined
      stuartofmt
      In plugin.json dwcVersion and sbcDsfVersion are defined to have single values.
      It does not seem possible to, for example, indicate that a plugin is compatible with 3.5.x and 3.6.x.
      Is this the case , or is there a way? It would be useful for plugin developers and users to not have to, unnecessarily, target specific plugin versions.
      I have tried e.g. >=3.5 and also tried an array ["3.5","3.6"] however neither are supported. The latter, BTW, fails silently.
      droftartsundefined T3P3Tonyundefined chrishammundefined 3 Replies Last reply Reply Quote 1
        droftarts administrators @stuartofmt
        @stuartofmt One for @chrishamm.
        • T3P3Tonyundefined
          T3P3Tony administrators @stuartofmt
          @stuartofmt I can see how this would be a useful addition, and distinct from just 3.x . That may work now, but would not necessarily be accurate at all.
          www.duet3d.com
          • chrishammundefined
            chrishamm administrators @stuartofmt
            @stuartofmt It is NOT possible - or at least not safe/recommended - to use the same compiled JS chunk for multiple DWC versions. But you can target DSF 3.x.x by specifying only "sbcDsfVersion": "3".
            Duet software engineer
            stuartofmtundefined 1 Reply Last reply Reply Quote 0
              stuartofmt @chrishamm
              @chrishamm
              Understood, as it relates to DWC. I may just use "sbcDsfVersion": "3" for the DSF only plugins.
              • stuartofmtundefined stuartofmt marked this topic as a question
              • stuartofmtundefined stuartofmt has marked this topic as solved
