    Z configuration for sensors
    1.3k
    • Timothee Leblondundefined
      Timothee Leblond
      I'm trying to configure my printer to use a microprobe.
      Thanks to the community, the microprobe is now wired successfully and reponds to commands in the console. I also just configured X and Y axes with stall detection and sensorless homing. As it is my first trial, I need to home printer's 3 axes. However, the microprobe isn't deploying nor palping the bed. I tried homing but I had to stop before it touches the bed. So either it is not working properly or maybe it is going too low.
      Would you have any leads for me?
      Board: Mini 5+
      Firmware: 3.5.4
      Microprobe: BTT BIQU microprobe
      Config.g
      ; Default config.g template for DuetPi
      ; Replace this with a proper configuration file (e.g from https://configtool.reprapfirmware.org)
      ; Display initial welcome message
      M291 P"You are operating an SBC image in standalone mode. Please see <a href=""https://www.duet3d.com/StartHere"" target=""_blank"">here</a> further information." R"Welcome to your new Duet 3!" S1 T0
      ; Enable PanelDue
      M575 P1 B57600 S1
      ; Enable network
      ; M552 P0.0.0.0 S1
      ; Configuration file for RepRapFirmware on Duet 3 Mini 5+ Ethernet
      ; generated by RepRapFirmware Configuration Tool v3.5.8 on Fri Dec 13 2024 08:59:52 GMT-0500 (Eastern Standard Time)
      ; General
      G90 ; absolute coordinates
      M83 ; relative extruder moves
      M550 P"Duet 3" ; set hostname
      M915 X Y S5 R1 F1 H2  ; set sensorless homing
      M302 P1   ; Allow cold extrusion
      ; Accessories
      M575 P1 S0 B57600 ; configure PanelDue support
      ; Wait a moment for the CAN expansion boards to become available
      G4 S2
      ; Smart Drivers
      M569 P0.0 S1 D3 V188; driver 0.0 goes forwards (X axis) -> D3 is for stealthChop mode = enable stall detection
      M569 P0.1 S1 D3 V188; driver 0.1 goes forwards (Y axis) -> D3 is for stealthChop mode = enable stall detection
      M569 P0.2 S1 D2 V188; driver 0.2 goes forwards (Z axis) -> D3 is for stealthChop mode = enable stall detection
      M569 P121.0 S0 D2 ; driver 20.0 goes forwards (extruder 0)
      ; Motor Idle Current Reduction
      M906 I30 ; set motor current idle factor
      M84 S30 ; set motor current idle timeout
      ; Axes
      M584 X0.0 Y0.1 Z0.2 ; set axis mapping
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M906 X800 Y800 Z800 ; set axis driver currents
      M92 X80 Y80 Z400 ; configure steps per mm
      M208 X-6:310 Y0:310 Z-5:405 ; set minimum and maximum axis limits
      M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
      M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
      ; Extruders
      M584 E121.0 ; set extruder mapping
      M350 E16 I1 ; configure microstepping with interpolation
      M906 E800 ; set extruder driver currents
      M92 E100 ; configure steps per mm
      M566 E120 ; set maximum instantaneous speed changes (mm/min)
      M203 E3600 ; set maximum speeds (mm/min)
      M201 E250 ; set accelerations (mm/s^2)
      ; Kinematics
      M669 K0 ; configure Cartesian kinematics
      ; Probes
      M950 P0 C"out6"                              ; Set servo output on Mini 5+
      M558 P9 H10 F250:30 T8000 C"^!io6.in"            ; Set probe input to IO_6 on Mini 5+
      G31 P500 X0 Y0 Z1.5                                  ; set Z probe trigger value, offset and trigger height
      ;M950 S0 C"121.io0.out"                              ; Set servo output on Rototoolboard
      ;M558 P9 H6 F250:30 T8000 C"^!121.io0.in"            ; Set probe input to IO_0 on Rototoolboard
      ;G31 P500 X0 Y0 Z0                                  ; set Z probe trigger value, offset and trigger height
      M574 X1 S3                            ; configure X axis endstop
      M574 Y1 S3                            ; configure Y axis endstop
      M574 Z1 S0                            ; configure Z axis endstop
      M915 X Y R0 F0
      M563 P0 S"MainExtruder" D0 ; create Tool 0 using Extruder Drive 0
      G10 P0 S0 R0 ; set Tool 0 active and standby temperatures to 0
      T0 ; select Tool 0 at startup
      Homeall.g
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.5.8 on Tue Dec 10 2024 15:03:23 GMT-0500 (Eastern Standard Time)
      ; increase Z
      G91 ; relative positioning
      G1 H2 Z5 F6000 ; move Z relative to current position to avoid dragging nozzle over the bed
      G90 ; absolute positioning
      ; home XY
      M400
      M913
      M400
      var xTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
      var yTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
      G1 H1 X{-var.xTravel} Y{-var.yTravel} F4000 ; coarse home in the -X and -Y directions
      G1 H2 X5 Y5 F4000 ; move back 5mm
      G1 H1 X{-var.xTravel} Y{-var.yTravel} F4000 ; fine home in the -X and -Y directions
      M400
      M913
      M400
      ; home Z
      var xCenter = move.compensation.probeGrid.mins[0] + (move.compensation.probeGrid.maxs[0] - move.compensation.probeGrid.mins[0]) / 2 - sensors.probes[0].offsets[0]
      var yCenter = move.compensation.probeGrid.mins[1] + (move.compensation.probeGrid.maxs[1] - move.compensation.probeGrid.mins[1]) / 2 - sensors.probes[0].offsets[1]
      G1 X{var.xCenter} Y{var.yCenter} F4000 ; go to bed centre
      G30 ; probe the bed
      homez.g
      ; homez.g
      ; called to home the Z axis
      ; ################# Home Z Preparation ################
      G91 															; Relative mode
      G1 H2 Z5 F5000													; Lower the bed
      G90
      G1 Z10 F4000       ; Move Z up 10mm to ensure clearance
      G1 X{var.xCenter} Y{var.yCenter} F4000 ; go to bed centre															; Back to absolute positioning
      G30					 											; Probe a single point
      Thanks!
      fcwiltundefined jay_s_ukundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @Timothee Leblond
        @Timothee-Leblond
        And the MicroProbe is responding to M401 and M402?
        I was never able to get that working. I will try testing my setup again.
        Unrelated but possibly of interest:
        In your homing files you have
        M400
        M913
        M400
        As far as I know they are serving no purpose.
        Also for your "coarse" and "fine" homing moves you have the same F values. Normally the "fine" move is done at a much slower speed. I don't see the need to do the same move twice if they are at the same speed.
        Waiting for verification that M401/M402 are working for you.
        Thanks, Frederick
        Timothee Leblondundefined 1 Reply Last reply Reply Quote 0
          jay_s_uk @Timothee Leblond
          @Timothee-Leblond you should be using G30 moves to home z, not G1 H1 Z
            Timothee Leblond @fcwilt
            @fcwilt
            Hi Frederick,
            Yes, the M401/M402 commands are working. M42 as well.
              Timothee Leblond @jay_s_uk
              @jay_s_uk
              So should I replace every G1 by G30 in my homez?
                @Timothee-Leblond https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_BLTouch#configuration-1
                See here for an example home all and homez file
                  @jay_s_uk
                  It looks like what I made initially?
                  I have a G1 going to center followed by a G30.
                    Phaedrux Moderator @Timothee Leblond
                    @Timothee-Leblond said in Z configuration for sensors:
                    M950 P0 C"out6"
                    This should be io6.out not out6 I believe.
                    Are you sure M401 and M402 are working to retract and deploy the pin? What do you have in your deployprobe.g and retractprobe.g files?
                    Your trigger pin is also inverted with the ! , which might lead to the probe triggering before it's even deployed. Are you sure it needs to be inverted?
                      Timothee Leblond @Phaedrux
                      @Phaedrux
                      I confirm M401/M402 are working with M950 P0 C"out6". On the contrary, it is not using M950 P0 C"io6.out".
                      Deploy
                      ; deployprobe0.g
                      ; called to deploy a physical Z probe
                      M42 P0 S1  ; Deploy probe
                      G4 P500      ; Pause for 500ms to ensure deployment
                      retract
                      ; retractprobe0.g
                      ; called to retract a physical Z probe
                      M42 P0 S0  ; Retract probe
                      I'm using a BTT not a BlTouch, and it is advised to use ^!io6. in apparently.
                        understood.
                        Can you show a photo of your probe wiring at the board?
                        When you send G30 manually, the Z axis moves, but the probe does not deploy? But M401/M402 do work?
                          @Phaedrux
                          First of all, when I send G30 it says: "Error: G30: Insufficient axes homed for bed probing".
                          When I try homing, I regularly have the same problem.
                          Right now, when I home all, the X bumps into the wall with a noise, the probe deploys, retracts then deploys and I then have that error message again without the Y being homed.
                          I know my first problem may be due to the stall detection and sensorless homing through M915 in config.g. I've been trying to set it up but I still have some problems.
                          M915 X Y S10 R1 F1 H2  ; set sensorless homing
                          The wiring had been thanks to an other discussion here: https://forum.duet3d.com/topic/37443/wiring-biqu-microprobe-to-duet-rototoolboard/43
                            Are you able to home X and Y independantly successfully?
                            Need to get that sorted first. If you want to pretend the axis are homed, you can move them manually to the correct location and then send G92 X0 Y0 to force the axis to be homed and at that position.
                            You can try adding M401 and M402 commands to deploy/retract the probe right before and after you send G30 in your homing files.
                              @Phaedrux
                              For X, homing is making a noise bumping the wall but it seems to work.
                              For Y, I have no problem homing it.
                              However, the home all is problematic.
                              Sending M92 X0 Y0 before homing Z gives the same Error answer.
                              I already have M401/M402 in my homing files before and after G30.
                                Can you share your most up to date homing files?
                                Can you capture and share the exact error messages you get and exactly when?
                                  @Phaedrux
                                  Sure:
                                  homeall:
                                  ; homeall.g
                                  ; increase Z
                                  ; home XY
                                  M400
                                  M913
                                  M400
                                  G1 H1 X{-var.xTravel} Y{var.yTravel} F4000 ; coarse home in the -X and -Y directions
                                  G1 H1 X{-var.xTravel} Y{var.yTravel} F1000 ; fine home in the -X and -Y directions
                                  M400
                                  M913
                                  M400
                                  ; home Z
                                  G1 X{var.xCenter} Y{var.yCenter} F1000 ; go to bed centre
                                  M401
                                  G30 ; probe the bed
                                  M402
                                  homex:
                                  ; homex.g
                                  ; called to home the X axis
                                  ; increase Z
                                  G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed
                                  M400
                                  M913 X40 Y40 ; drop motor current to 40% -> for sensorless homing
                                  M400
                                  ; home X
                                  var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
                                  G1 H1 X{-var.maxTravel} F3000                            ; coarse home in the -X direction
                                  G1 X5 F3000                                             ; move back 5mm
                                  G1 H1 X{-var.maxTravel} F1000                            ; fine home in the -X direction
                                  ; decrease Z again
                                  G1 H2 Z-5 F6000 ; move Z relative to current position
                                  M400 ; Wait for current moves to finish
                                  M913 X100 Y100 ; return current to 100% -> for sensorless homing
                                  homey:
                                  ; homey.g
                                  ; called to home the Y axis
                                  ; increase Z
                                  M913 X40 Y40 ; drop motor current to 70% -> for sensorless homing
                                  M400
                                  ; home Y
                                  var maxTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
                                  G1 H1 Y{var.maxTravel} F3000                            ; coarse home in the -Y direction
                                  G1 Y5 F3000                                             ; move back 5mm
                                  G1 H1 Y{var.maxTravel} F1000                            ; fine home in the -Y direction
                                  ; decrease Z again
                                  homez:
                                  ; homez.g
                                  G91 															; Relative mode
                                  G90
                                  G1 Z10 F3000       ; Move Z up 10mm to ensure clearance
                                  M401
                                  G30
                                  M402 ; retract probe
                                  config.g:
                                  ; Enable PanelDue
                                  M575 P1 B57600 S1
                                  ; Enable network
                                  ; M552 P0.0.0.0 S1
                                  ; General
                                  ; Accessories
                                  G4 S2
                                  ; Smart Drivers
                                  ; Axes
                                  ; Extruders
                                  ; Kinematics
                                  ; Probes
                                  M558 P9 H30 F250:30 T8000 C"^!io6.in"            ; Set probe input to IO_6 on Mini 5+
                                  G31 P500 X0 Y0 Z20                                  ; set Z probe trigger value, offset and trigger height
                                  M574 Z1 S2                            ; configure Z axis endstop
                                  M915 X Y R0 F0
                                  I had the error: Error: G30: Insufficient axes homed for bed probing when trying to home all axes at the same time. For some reasons after I restarted the printer, I seem I no longer have it.
                                  However, when I home all or home Z or send G30, the extuder gets all the way down ignoring the probe, hitting the bed. When I manually activate the pin of the probe before it reaches bed, this error appears: Error: G4: Probe already triggered at start of probing move.
                                  On top of that, it is not going to the center of the bed before probing and my X axes make a noise when homing which I can't solve.
                                  • fcwiltundefined
                                    @Timothee-Leblond
                                    For the sake of simplicity and not duplicating code this is how I code homeALL.g.
                                    M98 P"homeZ.g"
                                    M98 P"homeY.g"
                                    M98 P"homeX.g"
                                    You can change the order as best for your printer.
                                      @fcwilt
                                      Thanks for the tip, I'll do that in the future.
                                      But I'm not sure it will solve my problem right?
                                      fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      • fcwiltundefined
                                        @fcwilt
                                        No, nothing to do with your problem - it just makes things a bit simpler in that if you make a change to homing code for one axis (X Y or Z) you don't need to make the same change to homeALL.g
                                          @fcwilt
                                          This is smart, thank you though!
                                            I'm kind of at a loss for your probe issue. It's confusing why M401 would work to deploy the pin manually but not during the homing move.
                                            Have you tried manually positioning he probe at the center of the bed and then sending M401 and G30 to deploy and start probing?
