Slice Magnum Plus dual heaters
I am using the Duet3D 6HC. I have a Slice Engineering Magnum + HotEnd with two heaters. I have set my VIN for the 6HC to 24volts. I now need 24 volts to run the hot ends of the Magnum. Do I need to do anything or will it automatically be sent to these outputs,Out1,Out2,Out3?
Thanks
Daryl -
@darylprice out1, out2 and out3 are whatever the input voltage is
@jay_s_uk
Thank you you very much!
Daryl
