    Need help changing an X or Y coordinate into a variable
    Gcode meta commands
    432
    • Strider007undefined
      Strider007
      I need to be able to take an unknown X or Y coordinate and set it as a variable in a macro.
      I'm using the G38.2 command to find an edge for use in a calculation. The G38.2 command works as expected and stops correctly at the location it is triggered. I can see the X and Y locations on the DWC or by using a M114 command but I do not understand how to change that into a variable I can use in a macro for a calibration calculation.
      With a G30 command I can get the Z coordinate using
      "global.autoz_tempx0 = sensors.probes[0].lastStopHeight
      How can I accomplish this with the G38.2 command, having it provide the X or Y coordinate?
      Any help or direction would be greatly appreciated.
      • fcwiltundefined
        fcwilt @Strider007
        @Strider007
        Are you asking how to get the X and Y values to use in some gcode?
        Strider007undefined 1 Reply Last reply Reply Quote 0
          Strider007 @fcwilt
          @fcwilt Yes, I send a "G38.2 X10 F100" command, the machine moves until the sensor is tripped and stops. I want that exact X coordinate where it stopped as a number to be used in in alignment calculations.
          zuoyanundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
          • zuoyanundefined
            zuoyan @Strider007
            @Strider007 You can search "duet object model", it should be move.axes[0-1].machinePosittion -- You can also explore the object model list in DWC
            • fcwiltundefined
              fcwilt @Strider007
              @Strider007
              See if this will work:
              For the X:
              move.axes[0].machinePosition or move.axes[0].userPosition
              For the Y:
              move.axes[1].machinePosition or move.axes[1].userPosition
                Strider007 @fcwilt
                @fcwilt Thanks,
                Ok, tried all combinations of your suggestions and only got error messages as follows:
                Error: Bad command: move.axes[0].
                Error: Bad command: machinePosition
                I had hoped that would work and had tried it already. What am I missing here?
                I
                  Strider007 @zuoyan
                  @zuoyan
                  Its a long list, and I've looked through it multiple times. I probably should have mentioned that. That's when I found the two suggestions that fcwilt gave me but no success so far. Thanks
                    Strider007 @Strider007
                    @Strider007 Ok, now studying M409, and I think I got this working.
                    Thanks all
                    • fcwiltundefined
                      fcwilt @Strider007
                      @Strider007
                      Those are not to be executed - they are merely variables holding those values.
                      To use such values, say, to move to a position, you would do something like
                      G1 X{move.axes[0].machinePosition} Y{move.axes[1].machinePosition}
                      The question is do those variables hold the values you desire. Compare them against what you see in the DWC, assuming the DWC is showing the values you seek.
                        Strider007 @fcwilt
                        @fcwilt
                        Yes, when I echo, that is the number I want to store as a temp variable then use in calculations of tool offsets.
                        echo "it is", move.axes[0].machinePosition
                        it is -118.088
                        Thank you for your guidance. I believe I 've got it from here.
                        • fcwiltundefined
                          fcwilt @Strider007
                          @Strider007
                          To save a value from the Object Model (OM) into a local variable you do something like:
                          var Xvalue = move.axes[0].machinePosition
                          var Yvalue = move.axes[1].machinePosition
                          Or it you want it to be persistent so you can use it later or in other code:
                          global Xvalue = move.axes[0].machinePosition
                          global Yvalue = move.axes[1].machinePosition
                          Good Luck.
                            Strider007 @fcwilt
                            @fcwilt Exactly what I needed to get past my mental roadblock. Some small code blocks doing just what I need. Now to refine the hardware to go with it. Most appreciated Gilly
