    3.6.0 beta1 - RC1 - Laser not working
    Beta Firmware
    281
      jay_s_uk @cichaczech
      @cichaczech can you post a sample gcode file?
      cichaczechundefined 1 Reply Last reply Reply Quote 0
      • cichaczechundefined
        cichaczech @jay_s_uk
        @jay_s_uk
        ;Custom GCode device profile, user origin
        ;Bounds: X69 Y193 to X105 Y210
        G00 G17 G40 G21;Restore metric mode
        G54
        G90;Restore absolute mode
        G0 X-1.001 Y-1.001
        G91;Restore relative mode
        ;Cut @ 5001 mm/min, 101% power
        M42 P10 S0 ;Vypni napajeni Laseru
        G0 X37 Y1
        ;Layer C02
        M42 P10 S1 ;Zapni napajeni Laseru
        G1 X-37 S254 F5001
        G1 Y18
        G1 X37
        G1 Y-18
          @cichaczech that seems to be using M42 to turn on the laser?
          I think you need to check the settings in lightburn. you can find some suggested settings here
          https://github.com/TeamGloomy/LPC-STM32-RRFUserConfigs/tree/master/K40 CO2 Laser - SKR 2 - ESP - paulg4h#lightburn-settings
            @jay_s_uk I am using diode laser and M42 is just switching On/Off power supply to laser module for safety (when handling object inside laser machine). For switching laser output there is S command.
            In Lightburn I am using Custom Gcode (experimental) profile to get rid off M3, M5, M7, M8 ... commands.
              @cichaczech you need M3 and M5 commands
                dc42 administrators @cichaczech
                @cichaczech I only tested it from the console too. Perhaps it only works for isolated moves. I'll look at it again on Friday.
                  cichaczech @dc42
                  @dc42 , @jay_s_uk I managed to get it work.
                  In whole Gcode, even in the end script, there cannot be my M42 P10 S0 for disabling power supply to laser module and before first G1 command there must be G4 command.
                  Examples that not working:
                  ;USER START SCRIPT
                  M42 P10 S1
                  ;USER START SCRIPT
                  G54
                  G0 X-1.001 Y-1.001
                  ;Cut @ 5001 mm/min, 21% power
                  G0 X1 Y-18
                  ;Layer C02
                  G4 P1
                  G1 X-37 S50 F5001
                  G1 Y18
                  G1 X37
                  G1 Y-18
                  ;USER END SCRIPT
                  M42 P10 S0
                  ;USER END SCRIPT
                  or
                  G54
                  G0 X-1.001 Y-1.001
                  G0 X1 Y-18
                  ;Layer C02
                  G1 X-37 S50 F5001
                  G1 Y18
                  G1 X37
                  G1 Y-18
                  And this one works:
                  G54
                  G0 X-1.001 Y-1.001
                  G0 X1 Y-18
                  ;Layer C02
                  G4 P1
                  G1 X-37 S50 F5001
                  G1 Y18
                  G1 X37
                  G1 Y-18
                  or
                  G54
                  G0 X-1.001 Y-1.001
                  M5
                  G0 X1 Y-18
                  ;Layer C02
                  G4 P1
                  G1 X-37 S50 F5001
                  G1 Y18
                  G1 X37
                  G1 Y-18
                  M5
                  G90;
                  with Sticky Laser it fires independently on M3 S0 (M3 S255) before move or M5 after so I choose to run without them, for now.
                  dc42undefined 2 Replies Last reply Reply Quote 1
                    @cichaczech the issue appears to be that when a G1 move with parameter S0 is followed immediately by a G1 move with a nonzero S parameter, the laser is not turned on. This occurs even if the moves are sent from the console, e.g. when sending this:
                    g1 x-10 s0 g1 x50 s255 g1 x0
                    If I replace the s0 by s10 then it works as expected. I will fix this.
                      @cichaczech please try the firmware at https://www.dropbox.com/scl/fo/y03luwmbypirbxncla3rk/AAJFLPFsVdFylemyhkXsAac?rlkey=7cq4svp4rzl2ztdffpzq2ghjk&dl=0.
                      cichaczechundefined 1 Reply Last reply Reply Quote 1
                        cichaczech @dc42
                        @dc42 it is working now. Thank you.
                        • dc42undefined dc42 marked this topic as a question
