No 3.3V and 5V (no light)
You can see the diagnostic below, the 3.3V and 5V worked when I used the USB.
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3SW-6J1D0-3SD6N-9UVRF
Used output buffers: 1 of 24 (1 max)
Static ram: 25680
Dynamic ram: 92704 of which 0 recycled
Exception stack ram used: 236
Never used ram: 12452
Tasks: NETWORK(ready,1448) HEAT(blocked,1248) MAIN(running,3832) IDLE(ready,200)
Owned mutexes:
Last reset 00:00:15 ago, cause: power up
Last software reset at 2025-03-08 22:20, reason: Heat task stuck, spinning module PrintMonitor, available RAM 11984 bytes (slot 0)
Software reset code 0x00a9 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443380f BFAR 0xe000ed38 SP 0x20004b04 Task 0x4e49414d
Stack: 004252c9 00425338 41000000 00000000 00000000 00000000 00000000 3db851ee 41880000 3e178897 3e1cd04f bd9b4c45 3e3a346d 3e638f7d 3e9249ef 3bbc6ae5 39802008 c0a00000 00000000 60000010 00425339 20013340 0043fa09
Error status: 0
Free file entries: 10
MCU temperature: min 22.4, current 25.8, max 25.9
Supply voltage: min 0.5, current 1.3, max 1.3, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 37005916
Slowest loop: 0.96ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.44ms; fastest: 0.00ms
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 0 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address bc:dd:c2:45:c6:48
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26528
WiFi IP address 192.168.1.33
WiFi signal strength -74dBm, reconnections 0, sleep mode modem
Socket states: 2 0 0 0 0 0 0 0
ok
- WiFi -
@julienmal sounds like the onboard 5v regulator has died then
