1LC Driver 0 not responding
I am standing up a Duet3 Mini 5+ and 3 x 1LC (v1.3) boards that are connected to Obriter 2.0 extruders.
I'm banging my head against the printer trying to figure out what I am missing here.
I am unable to get the Orbiter motor to engage when connected to the 1LC. If I connect the motor to an open driver on the Duet (driver 0.4) I can get it to engage.
I am running the following Macro to test the motor operations:
M302 P1 T0 P0 echo "Begin Move" G1 E100 F100 echo "End Move" T-1 P0 M302 P0
When doing this with the motor connected to (0.4) on the Mini I see the motor turn. However, when I put the motor back to the 1LC (21.0) and execute the macro above I see the system show "Busy" in the web browser, but the motor never turns.
I've tried unplugging the motor and getting the same effect, the system never tells me any errors or wiring problems when on (21.0), but when on (0.4) it returns the expected error:
Warning: Driver 0.4 warning: phase A may be disconnected, phase B may be disconnected
I attempted to probe the B- & B+ / A- & A+ terminals after executing the Macro above on while connected to (21.0) I see no voltage. When I perform the same test with the motor connected to (0.4) I can see voltage.
I don't have everything configured on the 1LC, but so far I have validated all the other components are working so I know that the board is still good (same issue across 3 x 1LC's so far).
Any suggestions on what I can do to get some feedback from the 1LC as to why it's not working?
Below is the diagnostics right after attempting a move while the motor is connected to (21.0)
M122 B21 Diagnostics for board 21: Duet TOOL1LC rev 1.1 or later firmware version 3.6.0-rc.1 (2025-02-28 15:03:36) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) All averaging filters OK Never used RAM 7528, free system stack 94 words Tasks: Move(3,nWait 7,0.0%,96) TMC(2,nWait 6,0.5%,52) HEAT(2,nWait 6,0.3%,112) CanAsync(5,nWait 4,0.0%,58) CanRecv(3,nWait 1,0.0%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,72) MAIN(1,running,94.4%,318) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.8%,112), total 100.0% Owned mutexes: Last reset 00:11:33 ago, cause: power up Last software reset data not available Moves scheduled 1, hiccups 0 (0.00/0.00ms), segs 3, step errors 0 (types 0x0), maxLate 0 maxPrep 95, ebfmin 0.00 max 0.00 Peak sync jitter -3/8, peak Rx sync delay 212, resyncs 0/0, no timer interrupt scheduled, next step interrupt due in 3867598156 ticks, disabled VIN voltage: min 24.3, current 24.4, max 24.4 MCU temperature: min 20.4C, current 36.4C, max 36.4C Driver 0: pos 68999, 690.0 steps/mm, not present Last sensors broadcast 0x00000002 found 1 173 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 13892, send timeouts 0, received 6086, lost 0, ignored 0, errs 0, boc 0, free buffers 18, min 18, error reg 0 dup 0, oos 0/0/0/0, rxMotionDelay 292, adv 37067/37067 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, contentions 0, other errors 0
config.g (while connected to 1LC)
G90 ; absolute coordinates M83 ; relative extruder moves M911 S19.8 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss ;;;;;;;;;;;;;;;;;;; ;;; Network ;;; ;;;;;;;;;;;;;;;;;;; M552 S1 ; configure WiFi adapter M586 P0 S1 ; configure HTTP ;;;;;;;;;;;;;;;;;;;;;;;;; ;;; Smart Drivers ;;; ;;;;;;;;;;;;;;;;;;;;;;;;; M569 P0.0 S0 D2 ; driver 0.0 goes forwards (Z0 axis) M569 P0.1 S0 D2 ; driver 0.1 goes forwards (Z1 axis) M569 P0.2 S1 D2 ; driver 0.2 goes forwards (X axis) M569 P0.3 S1 D2 ; driver 0.3 goes forwards (Y axis) M569 P20.0 S0 D3 V4000 ; Tool Changer ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ;;;;;;;;;;;;;;;; ;;; Axes ;;; ;;;;;;;;;;;;;;;; M584 X0.2 Y0.3 Z0.0:0.1 ; set axis mapping M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M906 X800 Y800 Z800 ; set axis driver currents M92 X200.0157 Y200.0157 Z1601.584008 ; configure steps per mm M208 X0:427 Y0:410 Z0:380 ; set minimum and maximum axis limits M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min) M201 X500 Y500 Z20 ; set accelerations (mm/s^2) ; Tool Changer Start (C-Axis) ; M584 C20.0 ; Set Axis Motor M906 C400 ; Set Motor Currents (mA) M350 C8 I0 ; Set Interpolation M92 C100 ; Set Microstepping M201 C500 ; Set Accellerations M203 C5000 ; Set Maximum speed (mm/min) M566 C2 ; Set maximum instantaneous speed changes (mm/min) M208 C0:240 ; Set axis Min/Max travel ;M915 C S3 F0 H200 R0 ; Stall Detection ; Tool Changer End ; ; Kinematics M669 K1 ; configure CoreXY kinematics M575 P1 B115200 S1 ; PanelDue communications ;;;;;;;;;;;;;;;;;; ;;; Probes ;;; ;;;;;;;;;;;;;;;;;; ; Z-Axis (BLTouch) M558 K0 P9 C"20.io0.in" H5 F120 T6000 ; configure BLTouch probe via slot #0 G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height M950 S0 C"20.io0.out" ; create servo #0 for BLtouch ; Z-Axis End ;; Sensor to right (negative X) of hotend G31 P25 K0 X31.75 Y-34.4 Z0.90 ; Z probe trigger value, offset in relation to nozzle. Larger trigger brings hotend closer to bed. M557 X40:360 Y40:340 S40 ; Define mesh grid Offset X to account for Z-Trigger. ;;;;;;;;;;;;;;;;;; ;;; Endstops ;;; ;;;;;;;;;;;;;;;;;; ;M574 X1 S3 ; configure X axis endstop ;M574 Y1 S3 ; configure Y axis endstop M574 X1 S1 P"!20.io1.in" ; X-Axis Switch High Trigger M574 Y1 S1 P"io6.in" ; Y-Axis Switch High Trigger M574 Z1 S2 ; Z-Axis end stop is probe. ;;;;;;;;;;;;;;;;;;; ;;; SENSORS ;;; ;;;;;;;;;;;;;;;;;;; M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0 M308 S10 Y"mcu-temp" A"MCU" M950 J0 C"!20.io3.in" ; Tool Optical Sensor ;;;;;;;;;;;;;;;;;;; ;;; Heaters ;;; ;;;;;;;;;;;;;;;;;;; M950 H0 C"out0" T0 ; create heater #0 M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0 M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0 G4 S1 ; Heated beds M140 P0 H0 ; configure heated bed #0 ;;;;;;;;;;;;;;;;; ;;; Tools ;;; ;;;;;;;;;;;;;;;;; ;; Tool0 ;; ; !!! DEFINE MOTOR FOR EXTRUDER !!! M584 E21.0 ; set extruder mapping M906 E1000 I10 M350 E16 I1 ; configure microstepping with interpolation ; NOTE: See Smart Drivers section for motor currents M92 E690 ; configure steps per mm M566 E300 ; set maximum instantaneous speed changes (mm/min) M203 E7200 ; set maximum speeds (mm/min) M201 E3000 ; set accelerations (mm/s^2) ;; TEMP SENSOR M308 S1 P"21.temp0" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1 ;M308 S2 P"21.temp1" Y"thermistor" A"Tool0_Temp_Extruder" T100000 B4725 C7.06e-8 ; configure sensor #1 ;; Heater M950 H1 C"21.out0" T1 ; create heater #1 M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1 M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1 ;; FANS ;;; Tool Fan M950 F0 C"21.out2" ; create fan #0 M106 P0 S0 B0.3 H1 T45 ; configure fan #0 ;;; Extruder Fan ;M950 F1 C"21.out1" ; create fan #1 ;M106 P1 C"Tool0_Fan_Extruder" S0 L0 X1 B0.1 H2 T45 ; configure fan #1 ;;; Extruder Fan ;; Create Tool0 M563 P0 D0 H1 ; create tool #0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C ;; Tool0 End ;; ;M98 P"/sys/CAN_22.g" ;M98 P"/sys/CAN_23.g" ; Miscellaneous M501 ; load saved parameters from non-volatile memory ;M98 P"/sys/custom_global_vars.g"
I was running v3.5.4, but upgraded to 3.6.1 rc1 last night in an attempt to see if maybe it was just a bug, but no change.
@Gamefanatic3D
Okay, so I went through and tested each 1LC board without them all connected at the same time. It appears the issue is only with the (21.0) board. The other boards (22.0, 23.0) all work to include (20.0) which is running the tool head.I believe this may be an issue with the single board. Does this sound like a hardware issue?
I'll swap out this board soon to validate my assumption.
@Gamefanatic3D
Okay so I'm certain the driver is blown by the look in this picture.
Swapped out the board, and now to the next problem I'm sure I will have!I knew I'd figure it out once I asked for help!
@Gamefanatic3D Yes, that's definitely blown! Any reason you can see for it? Short circuited motor wiring, or shorted out on something it was mounted to? If you can take a good picture of each side of the board and post it hear, I can check for any manufacturing faults. Is the board new? If so, when and where did you purchase it from?
@droftarts
There is a sticker right under that driver.
This was a brand new board, but puchased in August 2024. I believe this might have been my fault. When creating my initial power cable to the Tool Distribution board about a month ago and got the PINs reversed in the circuit layout. I immediately powered off and reversed things at one end and plugged it in and didn't notice any issues. At least not until now...
None of the other boards had this issue since I had updated the build guide for those circuits.
