    File uploads failing Duet 3 mini 5 ethernet
    Duet Web Control
    • KeylAmiundefined
      KeylAmi
      M122 output:
      3/21/2025, 4:15:19 PM m122
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.4 (2024-11-24 10:44:24) running on Duet 3 Mini5plus Ethernet (standalone mode)
      Board ID: XYY98-FT8LU-F65J0-409NY-3Y03Z-HUG5K
      Used output buffers: 1 of 40 (34 max)
      Static ram: 103496
      Dynamic ram: 122492 of which 0 recycled
      Never used RAM 15760, free system stack 192 words
      Tasks: NETWORK(1,ready,26.4%,172) ETHERNET(5,nWait 7,0.7%,564) HEAT(3,nWait 1,0.0%,333) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.0%,939) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,0.8%,101) MAIN(1,running,70.5%,651) IDLE(0,ready,0.8%,29) AIN(4,delaying,0.8%,259), total 100.0%
      Owned mutexes:
      Last reset 00:03:17 ago, cause: software
      Last software reset at 2025-03-21 16:12, reason: User, Gcodes spinning, available RAM 15736, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      MCU revision 3, ADC conversions started 148490, completed 148490, timed out 0, errs 0
      MCU temperature: min 20.6, current 21.2, max 21.5
      Supply voltage: min 23.7, current 23.8, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 56, read errors 0, write errors 1, ifcnt 58, reads 10393, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, SG min 52, read errors 0, write errors 1, ifcnt 58, reads 10393, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 164, read errors 0, write errors 1, ifcnt 57, reads 10392, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 57, reads 10392, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 10393, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2025-03-21 16:15:29
      Cache data hit count 369782081
      Slowest loop: 360.90ms; fastest: 0.16ms
      === Storage ===
      Free file entries: 20
      SD card longest read time 3.8ms, write time 143.6ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      === DDARing 1 ===
      Bed heaters -1 -1 -1 -1, chamber heaters 1 -1 -1 -1, ordering errs 0
      Heater 0 is on, I-accum = 0.0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x0000803
      Code queue 0 is empty
      Code queue 1 is empty
      === CAN ===
      Messages queued 1780, received 0, lost 0, errs 930892, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 990/0/0
      Tx timeouts 0,0,989,0,0,789 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 2809.26ms; fastest: 0.04ms
      Responder states: MQTT(0) HTTP(4) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 3 of 8
      = Ethernet =
      Interface state: active
      Error counts: 0 0 0 0 0 0
      Socket states: 5 3 2 2 2 0 0 0
      Trying to upload a 50mb gcode file. tried updating to latest stable firmware. no change. tried power cycling, no change. cleared cache on two different browsers.
      Getting this in console on each attempt:
      3/21/2025, 4:16:44 PM Connection established
      3/21/2025, 4:16:42 PM Failed to upload CFFFP_3.21.25.gcode
      Could not complete action because the connection has been terminated
      3/21/2025, 4:16:42 PM Connection interrupted, attempting to reconnect...
      Network error
        droftarts administrators @KeylAmi
        @KeylAmi Check the SD card, by sending M39. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
        KeylAmiundefined 2 Replies Last reply Reply Quote 0
        • dc42undefined dc42 marked this topic as a question
        • KeylAmiundefined
          KeylAmi @droftarts
          @droftarts why was this marked as solved? I have not gotten a chance to get back to the printer and run M39
          • jay_s_ukundefined jay_s_uk has marked this topic as unsolved
          • KeylAmiundefined
            KeylAmi @droftarts
            @droftarts
            output from M39:
            SD card in slot 0: capacity 7.95GB, partition size 2.14GB, free space 1.72GB, speed 22.50MBytes/sec, cluster size 4kB
              @KeylAmi I'd reformat the card as one large 8GB partition. You're only using a 2GB partition, and though it's not full, there's not much space. Also the cluster size is small, which hampers SD card performance. Copy off all files, format and copy the files back. For formatting, see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#formatting
              KeylAmiundefined 1 Reply Last reply Reply Quote 1
              • KeylAmiundefined
                KeylAmi @droftarts
                @droftarts
                Alright. Thank you. I will give that a whirl.
                Currently in front 1/3rd of a 72hr print
