Duet 3 MB6HC – Sparks and Driver Failure Near Driver 1
I fear my Duet 3 6HC is toast: the smoke has come out of it. I figure I will report it here just in case there is some recourse and hopefully get a sense of what the root cause is.
Here is a photo of where I think the issue appears to be on driver 1. See the dots on the TMC2160 drivers. Visual inspection of the board seems to look normal otherwise.
I have running a Duet 3 MB6HC on RRF 3.5.4 SBC mode with 2x 3HC Expansion Boards. It has been working pretty solidly for the better part of a year now. The motor current was set to 800-1000mA (I forget exactly what I set it to, but definitely somewhere in this range)
Here is the sequence of events that got me here:
0.) Initial setup was working fine with 2x NEMA 23 Y-axis motors, running without issue for months. I decided to swap in NEMA 17 to see if I could get it to run quieter.
1.) Initial setup working fine with NEMA 17 Y-axis motors, but I missed the accelerations and speeds I could achieve with the NEMA 23.
2.) I reverted the NEMA 17s back to the NEMA 23s motors (wiring verified; proper coil pairs, no shorts).
3.) On first power-up after swap, heard an audible electrical snap and saw smoke. This was maybe a second after I powered it on, I don't think it had got to the point of running the config file yet. I yelped in surprise and powered off immediately.
4.) Disconnected all motors, outputs, and sensors. Powered up again. Board booted successfully. M122 reported all drivers as "ok". Web interface and MCU appeared functional.
5.) Gradually reconnected components: a) Plugged in all I/O except drivers b) Then connected X motor alone into driver 0.
6.) On powering up: sparks emitted from area near driver 1 (not driver 0).
7.) Powered off, unplugged X motor from driver 0, powered on again — sparks reappeared at same location.
8.) Board now fully powered off and removed from printer.I checked the NEMA 23 motor associated with driver 1 and the NEMA 17 motor associated with driver 0. The wires show continuity, the coils for each motor measure as expected, and no shorts to the motor housing are found.
Here is the M122 response
RepRapFirmware for Duet 3 MB6HC version 3.5.4 (2024-11-24 10:47:10) running on Duet 3 MB6HC v1.02 or 1.02a (SBC mode)
Board ID: 0JD2M-9P9DA-F0PSD-6JTD0-3S86S-TNT72
Used output buffers: 1 of 40 (23 max)
Static ram: 155464
Dynamic ram: 97720 of which 0 recycled
Never used RAM 92808, free system stack 202 words
Tasks: ACCEL(6,nWait 6,0.0%,343) SBC(2,rWait:,0.9%,801) HEAT(3,nWait 6,0.0%,321) Move(4,nWait 6,0.0%,335) CanReceiv(6,nWait 1,0.0%,796) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,9.1%,55) MAIN(2,running,89.7%,101) IDLE(0,ready,0.2%,29), total 100.0%
Owned mutexes: HTTP(MAIN)
Last reset 00:03:01 ago, cause: power up
Last software reset at 2025-04-02 10:15, reason: User, Platform spinning, available RAM 92096, slot 2
Software reset code 0x6000 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
Error status: 0x00
MCU temperature: min 20.4, current 33.0, max 33.1
Supply voltage: min 47.7, current 47.8, max 47.9, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.0, current 12.3, max 12.5, under voltage events: 0
Events: 7 queued, 7 completed
Driver 0: ok, SG min 0, mspos 0, reads 23706, writes 16 timeouts 0
Driver 1: ok, SG min 0, mspos 0, reads 23705, writes 17 timeouts 0
Driver 2: ok, SG min 9, mspos 9, reads 23707, writes 16 timeouts 0
Driver 3: ok, SG min 9, mspos 9, reads 23707, writes 16 timeouts 0
Driver 4: ok, SG min 9, mspos 9, reads 23707, writes 16 timeouts 0
Driver 5: ok, SG min 9, mspos 9, reads 23707, writes 16 timeouts 0
Date/time: 2025-04-02 10:28:36
Slowest loop: 26.76ms; fastest: 0.06ms
=== Storage ===
Free file entries: 20
DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
no step interrupt scheduled
Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
=== DDARing 0 ===
=== DDARing 1 ===
Bed heaters 2 3 4 5 6 7 -1 -1 -1 -1 -1 -1, chamber heaters 8 -1 -1 -1, ordering errs 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
File2 is idle in state(s) 0
Queue2 is idle in state(s) 0
Q0 segments left 0, axes/extruders owned 0x80000003
Code queue 0 is empty
Code queue 1 is empty
=== Filament sensors ===
check 0 clear 0
Extruder 2 sensor: no data received
=== CAN ===
Messages queued 1618, received 4997, lost 0, errs 0, boc 0
Longest wait 2ms for reply type 6060, peak Tx sync delay 5, free buffers 50 (min 49), ts 909/908/0
Tx timeouts 0,0,0,0,0,0
=== SBC interface ===
Transfer state: 5, failed transfers: 0, checksum errors: 0
RX/TX seq numbers: 6424/6424
SPI underruns 0, overruns 0
State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x24cfc
Buffer RX/TX: 0/0-0, open files: 0
=== Duet Control Server ===
Duet Control Server version 3.5.4 (2024-11-25 17:29:06, 32-bit)
HTTP+Executed:Executing M122
Code buffer space: 4096
Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
Full transfers per second: 8.44, max time between full transfers: 37.7ms, max pin wait times: 33.7ms/2.0ms
Codes per second: 0.21
Maximum length of RX/TX data transfers: 5725/1176
Anyways, I am hoping to see if there is any way to repair (seems unlikely) or other recourse, and if anyone has ideas on what the root cause could be.
@chrismbp I asked @dc42, he says:
Yes most likely the mosfet failed and it took out the driver chip too. Also possible that the driver chip failed and took out the other components.
I was wondering if this might be related to the failure of your 1HCL https://forum.duet3d.com/topic/37666/duet-3-1hcl-can-connection-timeout-after-config-changes ? The only linking factors I can think of is a failing/spiking PSU, or static discharge into the VIN or GND side of the boards.
