    Babystepping issue on 3.6.0 rc1
    Beta Firmware
    • ToWi1989undefined
      ToWi1989
      Changing babystepping while printing causes erratic stepper movement on 3.6.0 RC1 and fills log with repeating g0 g1 position outside machine limit errors. Can anyone else confirm/replicate?
        jay_s_uk @ToWi1989
        @ToWi1989 which way are you trying to baby step? Up or down? Also try RC2
        ToWi1989undefined 1 Reply Last reply Reply Quote 0
        • ToWi1989undefined
          ToWi1989 @jay_s_uk
          @jay_s_uk it's when babystepping in -Z. I've updated to 3.6.0 rc2 and the issue persists. I believe it has something to do with the bed mesh compensation thinking the machine is going outside its limits. Also, when restarting a new print, the babystepping value has to be increased with the previous value to get to nozzle at the correct height, and the reported z axis position will start to drift every time this is repeated (I'd expect this to get reset).
          Anyhow, I've now run a first level calibration print and set the probe offset accordingly (g31 in the config) so I don't need to use babystepping for now. I'm also not entirely sure if this is an isolated 3.6.0 issue since I've only had to start messing with the babystepping after I've had a crash with disabled axis limits 😅
          • Phaedruxundefined Phaedrux moved this topic from General Discussion
