    Z homing during print
    • sse1990
      sse1990 last edited by
      Just installed a replacement Duet Wifi board tonight. Ran through the configuration and everything moves as it should and is accurate.
      I loaded a 20x20mm calibration cube that I’ve used on this printer when I was using a ramps board. I can move all the Axis properly, I can “home all” no problem. But when I try and print, the Z axis wants to go back to the Home height. I did move it +1mm in the web control during a print and it does move, but as soon as the next layer goes to print, the Z axis goes back to the home height and it Tries to keep printing at the lower height, not higher like it’s supposed to.
        You asked the same question in another thread, and I have replied there.
