    Struggling with PID tuning on Duet 3 with custom CoreXY
    • aria_jamesundefined
      aria_james
      Hey everyone,
      I’ve just finished building a custom CoreXY printer using a Duet 3 board, a Smart Effector, and a high-flow hotend. The setup runs great overall, but I’m running into some issues with temperature stability — especially during longer prints with higher flow rates. The hotend temperature tends to drift a bit, and I’d like to tighten it up.
      I did the usual auto-tune, but I’m wondering if there are better ways to manually fine-tune or improve stability, especially for materials like ABS or Nylon that are a bit more sensitive. Has anyone dealt with this kind of issue on a similar setup?
      Any advice or experience you can share would be really appreciated!
      gloomyandyundefined dc42undefined droftartsundefined 3 Replies Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @aria_james
        @aria_james It would probably help if you could post a screenshot showing the sort of temperature variation you are seeing during a print.
          dc42 administrators @aria_james
          @aria_james said in Struggling with PID tuning on Duet 3 with custom CoreXY:
          When you say it is drifting, is that when the printer is idle or when it is printing? As it's a high flow hot end it's common to see the temperature drop when it starts extruding at a high rate. You can configure heater feedforward to combat that.
            droftarts administrators @aria_james
            @aria_james
            @dc42 said in Struggling with PID tuning on Duet 3 with custom CoreXY:
            See https://docs.duet3d.com/User_manual/Connecting_hardware/Heaters_tuning#heater-feedforward
