    Can check content bed.g?
    • peirofundefined
      peirof
      I follow do work Bltouch in Duet…
      A- the individual gcode [c]G30 S-1[/c] works
      B- The problems apear when try autocalibrate printer… I have headcrash
      When I send autocalibrate, Duet do the orders content in [c] bed.g[/c]. No?
      Maybe… The error is in [c] bed.g[/c], moreover, my [c] bed.g[/c] is the same when I was installed MINI IR PROBE
      Copy and paste my [c] bed.g[/c], if you can see some error.
      The only important difference, is that G30, have the flag H0.
      A thing that I don't understand is that… When I try autocalibrate, Duet do the orders in [c] bed.g[/c]. No?
      When I try do autocalibrate… First printer homes, and after down nozzle straight and in this point, x0 y, I have the headcrash but the first point in [c] bed.g[/c] is [c] G30 P0 X0.00 Y135.00 Z-99999 H0 [/c]
      [[language]]
      ; bed.g; bed.g file for RepRapFirmware, generated by Escher3D calculator
      ; 16 points, 6 factors, probing radius: 140, probe offset (0, 0)
      M561                        ; clear any bed transform, otherwise homing may be at the wrong height
      G31 X0 Y0                    ; don't want any probe offset for this
      G28                            ; home the printer
      G30 P1 X116.91 Y67.50 Z-99999 H0
      G30 P2 X116.91 Y-67.50 Z-99999 H0
      G30 P3 X0.00 Y-135.00 Z-99999 H0
      G30 P4 X-116.91 Y-67.50 Z-99999 H0
      G30 P5 X-116.91 Y67.50 Z-99999 H0
      G30 P6 X0.00 Y67.50 Z-99999 H0
      G30 P7 X58.46 Y-33.75 Z-99999 H0
      G30 P8 X-58.46 Y-33.75 Z-99999 H0
      G30 P9 X0 Y0 Z-99999 S6
      G1 X10 Y10 F3000
      M500
      Another try I want to do is downgrade firmware. In what firmware is tested Bltouch works?
      Thanks
        You should remove the G31 X0 Y0 line, that was for very old firmware.
        After you home the printer by sending G28, the effector should be close to its maximum height and ni the centre. The web interface should show the position as X=0, Y=0, Z= [height of nozzle above the bed]. Is that what you get?
        Please post your deployprobe.g, retractprobe.g, config.g and homeall.g files.
        I suggest you don't downgrade the firmware, it will complicate matters and make it harder for me to support you.
        PS - in bed.g you should add a M401 command before the first G30 command to deploy the probe, and M402 after the last one to retract it.
        • peirofundefined
          peirof
          In [c]bed.g[/c], its necesary redeply BlTouch after each [c]G30[/c]?
          How?
          P.D.; After send content of configuration files in Duet
          • peirofundefined
            peirof
            post contents….
            One deatail, maybe important, deployprobe.g and retractprobe.g are in [c]macro/BlTouch[/c], directory…
            deployprobe.g
            [[language]]
            M280 P3 S10 I1
            retractprobe.g
            [[language]]
            M280 P3 S90 I1
            config.g
            [[language]]
            ; Configuration file for Duet Ethernet (firmware version 1.17)
            ; generated by RepRapFirmware Configuration Tool on Mon May 22 2017 22:56:20 GMT-0400 (Eastern Daylight Time)
            M111 S0 ; Debugging off
            G21 ; Work in millimetres
            M555 P1 ; Set firmware compatibility to look like RepRapFirmare
            M665 R165 L360.25 B175 H550; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
            M208 Z0 S1 ; Set minimum Z
            ;Ajustar la escala en los ejes, en las Delta, bufff
            M579 X1 Y1 ;
            M574 X2 Y2 Z2 S1 ; Define active high microswitches
            M557 R130 S30 ; Define mesh grid
            ; BlTouch
            M307 H3 A-1 C-1 D-1 ;
            M558 P5 X0 Y0 Z1 H5 F100 T2000
            G31 X0 Y0 Z0 P25
            M350 X32 Y32 Z32 E16 I1 ; Configure microstepping with interpolatio
            M92 X160 Y160 Z160 E2470 ; Set steps per mm
            M566 X600 Y600 Z600 E40 ; Set maximum instantaneous speed changes (mm/min)
            M203 X12000 Y12000 Z12000 E3000 ; Set maximum speeds (mm/min)
            M201 X600 Y600 Z600 E1500 ; Set accelerations (mm/s^2)
            M906 X1200 Y1200 Z1200 E7200 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M143 S285 ; Set maximum heater temperature to 285C
            M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
            M305 P0 R4700 T100000 B3950 ; bed
            M563 P0 D0 H1 ; Define tool 0
            M550 Duet3D ; Set machine name
            M587 S"DLink-869L.2,4" P"a1b2c3d4" I192.168.1.99; Configure access point. M587 S"NOMBRE RED" P"PASSWORD"
            M586 P0 S1 ; Enable HTTP
            M586 P1 S1 ; Enable FTP
            M586 P2 S1 ; Enable Telnet
            M552 S1
            M106 P0 S0 I0 F255 H-1; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 F255 H1 T50; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S1 I0 F255 H1 T50; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            homdelta.g, i don't have homeall.g
            [[language]]
            ; homedelta.g
            ; Use relative positioning
            G91
            ; Move all towers to the high end stopping at the endstops (first pass)
            G1 X527 Y527 Z527 F1800 S1
            ; Go down a few mm
            G1 X-5 Y-5 Z-5 F1800 S2
            ; Move all towers up once more (second pass)
            G1 X10 Y10 Z10 F360 S1
            ; Move down a few mm so that the nozzle can be centred
            G1 Z-5 F6000
            ; Switch back to absolute positioning and go to the centre
            G90
            G1 X0 Y0 F1000
            M280 P3 S160 I1 :blt alarm release
              deployprobe.g and retractprobe.g must be in the /sys directory, because that is where the firmware looks for them.
              In bed.g, its necesary redeply BlTouch after each G30?
              No. Just use M401 before the first G30, and M402 after the last one.
