    Bad command: endif
    • Macgyverundefined
      Macgyver
      Running 3.5.4 firmware on my printer, Trying to do a macro for a calibration tool
      Here is the problem section of code
      ; Check if we got a trigger by checking if we moved down significantly
      var trigger_detected = move.axes[2].machinePosition < (var.safe_nozzle_height - 0.5) ; Check if we moved down significantly
      echo >>"0:/sys/IDEX_Z_offset.log" {state.time}, "Checking trigger detection: ", var.trigger_detected
      ; If no trigger was detected, abort
      if !var.trigger_detected
      echo >>"0:/sys/IDEX_Z_offset.log" {state.time}, "ERROR: No touch detected - aborting"
      M291 S2 R"Error" P"No touch detected after moving 9mm. Check the calibration tool and try again."
      M99 ; Exit macro if no trigger
      else
      echo >>"0:/sys/IDEX_Z_offset.log" {state.time}, "Touch detected successfully"
      endif
      Keep getting the error message - Error: Bad command: endif, It looks right to me but its late and I gotta be missing something. Can someone do a sanity check for me or have I run across something I cannot do?
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Macgyver
        @Macgyver there's no endif in RRF.
        You just have to have the code indented correctly. No indent means the if has finished
          droftarts administrators @Macgyver
          @Macgyver see https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#conditional-construct
