    Temperature measurement of stepper stator winding
    • shirnschallundefined
      shirnschall
      I would like to measure the stepper motor temperature by placing an ntc (100k, without a metal case) directly on the stator winding. However, I am unsure if the E/B field of the motor causes a problem for the electronics/measurement.
      Has anyone tried this yet?
      My printer: DIY 2020 extrusion CoreXY with E3D Tool-changing and Duet3 (https://github.com/shirnschall/HS-Bot-Project)
        jay_s_uk @shirnschall
        @shirnschall the kraken motors have thermistors embedded in them so I doubt there's any issues. The ones they use are nothing special
        shirnschallundefined JackMartinezundefined 2 Replies Last reply Reply Quote 0
          shirnschall @jay_s_uk
          @jay_s_uk
          Thank you for the reference! After thinking some more about it I think the current in both legs of the ntc should be common mode? I will test it as soon as possible.
          • JackMartinezundefined
            JackMartinez @jay_s_uk
            @jay_s_uk said in Temperature measurement of stepper stator winding:
            Thank you so much for the info.
