    Testing Endstops
    • DuetCDHundefined
      DuetCDH
      (Note: below I had to replace '.' with '@' in the io0 string because the forum system was considering it a 'link' and didn't let me post it)
      MB6XD v1.02, firmware 3.5.1
      Endstop definition
      M574 X1 S1 P"io0@in"
      I measure about 3v on io0@in (i read that there is a pullup on it).
      When I short io0@in to GND I get no indication that the input is active. I read that, in DWC 3.5 or greater (I think mine is 3.5.1) the axis letter in the status pane should have a green background. Mine does not change (never green).
      Is there another way to show that status of the input?
      Is the "Object Model" data static config data or live "state" data? It says the Input 0 is active = true
      Is there another config line needed to activate the input? The M754 is after my M584:
      M584 X0.0 Y0.1 Z0.2 U0.3 S0 ; set axis mapping
      After this is solved, what is the appropriate "S" value for a 5v logic provided signal that is 5v when not active and 0v when the limit is hit?
      jay_s_ukundefined DuetCDHundefined droftartsundefined 3 Replies Last reply Reply Quote 0
        jay_s_uk @DuetCDH
        @DuetCDH the 1.02 6XD isn't fully supported until 3.5.3 so best update
        • DuetCDHundefined
          DuetCDH @DuetCDH
          @DuetCDH Will do ...
          I just discovered that, even though DWC does not show the endstop signal change, it is active because the "homex" is acting on it.
          DuetCDHundefined 1 Reply Last reply Reply Quote 0
          • DuetCDHundefined
            DuetCDH @DuetCDH
            @DuetCDH Updated to 3.5.4 and status window now shows green highlight when at the limit.
            Thanks ...
            Now off to wire up the other three axes ...
            • DuetCDHundefined DuetCDH marked this topic as a question
            • DuetCDHundefined DuetCDH has marked this topic as solved
              droftarts administrators @DuetCDH
              @DuetCDH said in Testing Endstops:
              I'm not sure when this functionality was added originally, but I though from 3.5.0. However, if you're in CNC mode, it wasn't supported until DWC 3.5.3, see https://github.com/Duet3D/DuetWebControl/wiki/Changelog-DWC-3.x#version-353-changes-since-352
