    resume misses first Z move
    Beta Firmware
    • jltxundefined
      jltx
      Is this a known bug? I'm on 3.6.0-rc2
      I am doing a sequential object print. I wanted to make sure the clearance was correct so I inserted an M226 between objects. It paused, moving the toolhead into the corner. I hit resume so I could watch the clearance. The toolhead moved to the next object position, but did not drop to the bed. It hovered in air printing, then dropped to the bed and printed the rest correctly.
      Here is the relevant snippet of gcode. You can see the first object finishes at Z42.32. The first G1 command after the M226 correctly includes the Z axis but this is the only mention of Z until the bottom surface starts later due to a Z hop. What I observed exactly matches the idea that the first Z was missed, printing the perimeter in air at Z42 before correctly printing the bottom surface on the bed. This print had three objects and this happened exactly the same each time.
      Since I was able to confirm that the toolhead clearance is good I have done subsequent sequential object prints without the M226 and they all complete correctly.
      ;WIDTH:0.506548
      G1 F5759.607
      G1 X115.245 Y285.308 E.02122
      ;WIDTH:0.505875
      G1 F5768.303
      G1 X114.853 Y285.167 E.02118
      ;WIDTH:0.50834
      G1 F5736.57
      G1 X114.221 Y284.79 E.03761
      G1 X113.82 Y284.418 E.028
      ;WIDTH:0.509651
      G1 F5719.841
      G1 X113.435 Y283.884 E.03373
      ;WIDTH:0.510099
      G1 F5714.159
      G1 X113.144 Y283.165 E.03985
      ; stop printing object eab30995c923a37a9c8d92ac0c00f5ed166a4fb3.stl id:0 copy 0
      G1 E-.8 F1800
      M205 X5 Y5
      M486 S-1
      G1 Z42.32 F30000
      G1 X221.89 Y62.896 Z42.32 F30000
      G10 S220 ; set nozzle temperature
      M226
      M106 S0
      ;LAYER_CHANGE
      ;Z:0.2
      ;HEIGHT:0.2
      ;BEFORE_LAYER_CHANGE
      ;0.2
      G92 E0
      ;AFTER_LAYER_CHANGE
      ;0.2
      ;M3291 B"DuetLapse3.snapshot"
      ;_SET_FAN_SPEED_CHANGING_LAYER
      M204 P500
      M205 X5 Y5
      ; printing object e966342e2d4ec02d8d7194e4724d29f4f5f432f7.stl id:1 copy 0
      M204 T500
      M486 S1
      G1 X197.017 Y59.023 Z.2 F30000
      G1 E.8 F1800
      ;TYPE:Inner wall
      ;WIDTH:0.499999
      G1 F3000
      G1 X196.822 Y59.089 E.00768
      G1 X162.988 Y59.089 E1.2602
      G1 X162.764 Y59.023 E.00869
      G1 X162.698 Y58.828 E.00768
      G1 X162.698 Y24.993 E1.26021
      G1 X162.763 Y24.769 E.00869
      G1 X162.959 Y24.703 E.00768
      G1 X196.794 Y24.704 E1.26021
      G1 X197.017 Y24.769 E.00868
      G1 X197.083 Y24.993 E.0087
      G1 X197.083 Y58.799 E1.25913
      G1 X197.029 Y58.985 E.00721
      G1 X197.333 Y59.362 F30000
      ;TYPE:Outer wall
      G1 F3000
      G1 X197.138 Y59.492 E.00874
      G1 X196.867 Y59.546 E.01029
      G1 X162.988 Y59.546 E1.26188
      G1 X162.644 Y59.493 E.01295
      G1 X162.434 Y59.353 E.00939
      G1 X162.294 Y59.143 E.00937
      G1 X162.24 Y58.873 E.01028
      G1 X162.24 Y24.993 E1.26188
      G1 X162.294 Y24.65 E.01295
      G1 X162.434 Y24.44 E.00938
      G1 X162.643 Y24.3 E.00939
      G1 X162.914 Y24.246 E.01028
      G1 X196.794 Y24.246 E1.26189
      G1 X197.137 Y24.3 E.01294
      G1 X197.347 Y24.44 E.00939
      G1 X197.487 Y24.649 E.00939
      G1 X197.54 Y24.993 E.01297
      G1 X197.54 Y58.799 E1.25913
      G1 X197.487 Y59.143 E.01298
      G1 X197.36 Y59.333 E.0085
      G1 E-.8 F1800
      G1 X197.061 Y51.706 Z.6 F30000
      G1 X196.007 Y24.849 Z.6
      G1 Z.2
      G1 E.8 F1800
      ;TYPE:Bottom surface
      ;WIDTH:0.502729
      G1 F6300
      G1 X196.731 Y25.573 E.03839
      G1 X196.731 Y26.224 E.02436
      G1 X195.562 Y25.054 E.06196
      G1 X194.911 Y25.054 E.02438
      G1 X196.731 Y26.874 E.09644
      G1 X196.731 Y27.524 E.02436
      G1 X194.261 Y25.054 E.13091
      G1 X193.61 Y25.053 E.02438
      G1 X196.731 Y28.174 E.16539
      G1 X196.731 Y28.825 E.02436
      G1 X192.96 Y25.053 E.19986
      G1 X192.309 Y25.053 E.02438
      G1 X196.731 Y29.475 E.23434
      G1 X196.731 Y30.125 E.02436
      G1 X191.658 Y25.052 E.26881
        @jltx said in resume misses first Z move:
        3.6.0-rc2
        Can you test with 3.6.0-rc3 that was just released?
        jltxundefined 1 Reply Last reply Reply Quote 0
        • Phaedruxundefined Phaedrux moved this topic from Firmware installation
        • jltxundefined
          jltx @Phaedrux
          @Phaedrux said in resume misses first Z move:
          3.6.0-rc2
          It is still doing it on rc3. Should I file a bug?
            dc42 administrators @jltx
            @jltx please post your pause.g and resume.g files.
            • jltxundefined
              jltx @dc42
              I forgot those are macros. I copied these from somewhere way back. Is the first G1 R1 resetting the restore point such that the second one should be G1 R1 Z-5? Presumably this worked on an older firmware for whoever set it up.
              pause.g
              ; pause.g
              ; called when a print from SD card is paused
              M300 S2500 P300 ; beep when done
              M83          ; relative extruder moves
              G1 E-2 F3600 ; retract 2mm of filament
              G91          ; relative positioning
              G1 Z5 F360   ; lift Z by 5mm
              G90          ; absolute positioning
              ; Go to back right position for easy access
              G1 X310 Y310 F6000
              resume.g
              ; resume.g
              ; called before a print from SD card is resumed
              G1 E2 F3600    ; Extrude some stock to counter oozing
              G1 R1 Z5 F6000 ; go to 5mm above position of the last print move
              G1 R1          ; go back to the last print move
                @jltx you should add X0 Y0 to your two G1 R1 commands in resume.g. Also add Z0 to the second one.
