    DUET MB6HC -NO XYZ PROBE- Firmware & DWC updated to 3.5.4
    • peteupshallundefined
      peteupshall
      I have just updated the firmware and DWC on my duet 3 board but I cannot see a touch probe window on the dashboard as in the previous version.
      My probe settings are:
      ; Probe configuration executed by config.g
      M558 P5 C"!io0.in" H5 F500 T500 ; Set Z probe and use IO0.in inverted
      ;G31 P500 X10 Y10 Z4.766 ; set current probe status
      ;M557 X15:215 Y15:195 S20
      I have the flat plate the same as the ooznest probe which does XYZ and was controlled from the touch probe window on the Dashboard.
      Can anyone help to sort this orlet me know how I can roll back the DWC version pease.
        droftarts administrators @peteupshall
        @peteupshall Do you mean the 'touch probe window' as shown here? https://learn.ooznest.co.uk/Guide/Assembling+Your+Original+WorkBee+XYZ+Touch+Probe/61#s496
        This is Ooznest's version of DWC, not maintained by Duet3D. If you updated using the Duet3D firmware and DWC, it doesn't have the touch probe window built-in. You will have to wait for an update from Ooznest. As far as I'm aware, they are still using RRF/DWC 3.3: https://learn.ooznest.co.uk/Wiki/WorkBee_Firmware_Releases
        You may be able to recreate the touch probe window functionality in @MintyTrebor 's BtnCmd.
