    Z access moves when other access is pressed
    • theidemanundefined
      theideman
      I am just starting to set up my Duet WIFI, I am setting it up just like I did for my Smoothieboard, one axis at a time. I currently have only the z axis wired up and working. But the problem I am having is, if I press on x or y axis the z motor is moving, not the same, It just kinda buzzes and moves just a little. Does anyone have any idea what is happening?
      TOm
      • ShadowXundefined
        ShadowX
        Make sure you are using cartesian setup files. It sounds like you might be using the Kossel delta settings. You shouldn't be setting up one motor at a time if you are on a delta printer.
          Also make sure that your printer isn't trying to use bed compensation yet.
            theideman
            I got it taken care of there was a line in my config that was the problem.
            THANKS FOR ALL YOUR HELP..
            Tom
