File in /Sys folder with or without (U2) .g?
  • Hi,
    i have created a file in Duet Web Control, in /sys folder, when ask me for the name….
    i have to call with end .g, or without end .g, and system put automatic?
    If i name with end (.g) and after system put.... the file was double (.g).
    For example:
    bed file... if i name it bed.g, and after system add .g... the final name will be bed.g.g... and system will not recognize it
    mmm....
    I can't reproduce this. I just created a file called test.g in the System Editor page of DWC 1.20 and it worked, it didn't add an extra .g. Are you using DWC 1.20, or an older version?
