How to switch my extruder fromE0 to E1
Hi I dont believe my extruder E0 connection is working so I wanted to try the E1 spot. How do I change this in my config file?
You can change tool 0 to use extruder drive 1:
https://duet3d.com/wiki/G-code#M563:_Define_or_remove_a_tool
find this M563 P0 line in your config.g and change it to
M563 P0 D1 H1
If you have mapped fan to the tool keep those the same (Fxx) in the command
Did you mean the E0 motor or the E0 heater is not working? Tony's instructions above are for changing the motor over to the E1 motor connector.
Its for the heater not the motor, DC42 you are assisting me on another older thread i opened with this issue. I responded on that one with the changes you requested. Heater 2 now says 2000 degrees. Maybe I should delete one of these threads to not confuse or waste anyones time.
See my reply in that thread.
