MB6HC and Toolboard issues
Before ill start Questioning, ill have to explain the past of this printer.
i bought a Guider 2S in 2019 with the intent to just print stuff. I didnt wanted to "nerd-down" this printer - just use it....
2 Burned Mainboards, and some heating issues later i decided to throw the Flashforge electronics away, and rebuild it with Duet.Bought and successfully installed an MB6HC.
After about a year of working just fine, the Flashforge OEM toolboard burned.
Bought a Duet toolboard, installed it, wired it.7.6.2025, 12:32:39 M122 b121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.4.6 (2023-07-21 14:17:33) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 2596, free system stack 88 words Tasks: Move(notifyWait,0.0%,155) HEAT(notifyWait,0.4%,111) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,91.7%,343) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0% Last reset 00:02:23 ago, cause: software Last software reset data not available Driver 0: pos 0, 1553.5 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 162, reads 6218, writes 14, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 0/4, peak Rx sync delay 207, resyncs 0/0, no step interrupt scheduled VIN voltage: min 25.2, current 25.2, max 25.2 MCU temperature: min 31.8C, current 32.0C, max 32.2C Last sensors broadcast 0x00000002 found 1 76 ticks ago, 0 ordering errs, loop time 1 CAN messages queued 2897, send timeouts 0, received 1331, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, other errors 0
sooo,
Communication is working.
ive done the rest of rewireing.
Heater + FAN - works!
CoolingFan - works!Servo for Leveling - well here is the first Problem:
; Z-Probe M558 P8 C"121.io0.in" H3 F100 T8000 ; set Z probe type to switch and the dive height + speeds G31 P200 X0 Y0 Z2.5,;Z1.3 ;X-10 Y-25 Z2.5 M557 X0:280 Y0:210 S20:30 ; define mesh grid M376 H8 M950 S8 C"121.io0.out"
Thats my current config after 4h troubleshooting.
But i can not move the servo with M401 / M402.So if i am right, M401 / 402 just calling retract.g / deploy.g in the /sys/ folder.
so i took the comand in that file and tested it direct:
M280 P8 S20
And the Servo Moves...
So it seems, that my config is correct, but M401/402 is pointing to an other file?
Ive even tryed to rename deploy.g and retract.g as described in the Documentation, to deploy8.g and retract8.g
Didnt work...I do not understand why just changing the adress is making that problem. Surly just a small failure of my own, but i dont see it...
The second Problem is,
that the ExtruderMotor is not working.; Drives M569 P0.0 S1 ; physical drive x 0.0 goes forwards M569 P0.1 S1 ; physical drive y 0.1 goes forwards M569 P0.2 S0 ; physical drive z 0.2 goes forwards M569 P121.0 S1 ; physical drive extruder 0.3 goes forwards M584 X0.0 Y0.1 Z0.2 E121.0 ; set drive mapping
Config looks like this.
After heating up, i placed a piece of filament in it, i wanted to test the extrudtion via the DWC.no movement - not even noise...
Ive checked the wireing - it is correct - but i dont see how i can measure if the Port is working...
Ive measured the Motor to verify that the coils are ok - both are at 3,1 Ohms and dont have connection to gnd (case)Sooo, any Ideas?
Duet Web Control 3.4.6
Duet 3 MB6 HC 3.4.6
Toolboard V1.1 3.4.6
Its a cartesian Printerpls somebody help me
it can only be a small dumb failure of my own... but i dont see it... -
Your firmware is quite old and no longer supported. I suggest you go through the process to update, and we can trouble shoot from there.
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.6.0
Peruse the change log
Download the zip file and upload it through DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.6.0/Duet2and3Firmware-3.6.0.zip
@Phaedrux Yes sir, ill try that now.
@Phaedrux Damn, nailed it!
everything is working!
i even got an Z-Probe field, whre i can check if that probe is working!
if we ever meet, ur beer is paid by me!
THANKS!
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
