    Measure lenght with stall detection?
    794
    • AS-3D Druck
      AS-3D Druck last edited by
      Hi Guys,
      i've got a Question about a possible way to measure the Axis lenght with the stall detection Feature.
      Is there already a function/Gcode to do this?
      Best regards
      AS-3D Druck / Andre
        Yes, in firmware 1.20. First home the printer to one end of the axis as normal. Then use M574 to change the endstop for that axis to a stall detection endstop at the other end. Then use a G1 S3 command to move to beyond where the end of that axis is likely to be. It will set the corresponding M208 parameter to the axis position at which the stall occurs.
        You will need to tune the stall detection first.
        • AS-3D Druck
          Thank you, i already got a working stall detection Makro. 🙂
          So i just have to edite it a bit more. (I post it after i got it working)
          Best regards
          AS-3D Druck / Andre
          • Captain_sq
            Captain_sq last edited by
            It might be a good idea to temporarely lower the motor current for that axis during the stall detection movement too.
            Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
            Embedded systems designer, RC Pilot, maker and Gadget-o-holic
            • AS-3D Druck
              @Captain_sq:
              Like this? 😉
              [[language]]
              M913 X50 Y50
              Best regards
              AS-3D Druck / Andre
              • AS-3D Druck
                Ok, i tryed this, but it it dosen't show me something in the Console.
                [[language]]
                ; This File is just for testing the "stall detection" Feature.
                ; It might need to be adjusted to get it to work with you're Printer/s
                ; Sensorless Homing test file for RepRapFirmware on D-Bot
                M915 XY S4 F0 R1
                ; More about M915 and how to set it up you can find here:
                ; https://duet3d.com/wiki/G-code#M915:_Configure_motor_stall_detection
                ; Home X and Y
                G28 X0 Y0
                ; Setup Stall Detection on CoreXY for Xmax Ymin
                M400							; make sure everything has stopped before we make changes
                M574 X2 Y1 S3					; set endstops to use motor stall
                M913 X50 Y50					; reduce motor current to 50% to prevent belts slipping
                G91								; use relative positioning
                G1 S3 X500 F4000				; move the X to max until it detects the max Point
                G1 X-30							; move X away from max Point
                M400							; wait untill X is done
                G1 S3 Y-500 F4000				; move the Y to min until it detects the min Point
                G1 Y30
                G90								; back to absolute positioning
                M400							; make sure everything has stopped before we reset the motor currents
                M913 X100 Y100 Z100				; motor currents back to normal
                G1 X160 Y100 F2000					; centre the head and set a reasonable feed rate
                M574 X1 Y2 Z1 S0				; set endstops back to normal (is maybe different than you're normal)
                Best regards
                AS-3D Druck / Andre
                  You will need to send M208 to find out the new axis length.
                  • Captain_sq
                    @AS-3D:
                    @Captain_sq:
                    Like this? 😉
                    [[language]]
                    M913 X50 Y50
                    Yes, that will probably work nicely, but isn't F4000 a bit fast running the gantry into its physical endstop?
                    /Thom
