    Esimate weight of printed object…
    • peirofundefined
      peirof
      When i slice a object for print it…. Slicer, say me de leght of filamente i will use...
      How i can estimate weight of printed object?
      1- I suppose that each material will have a density, a weight per meter
      2- Does that density change from the roll to the extruded material?
      3- The density of a material (ABS, PLA, PETG, ....), changes according to the manufacturer? (In an appreciable way)
      4- When the Slicer tells you the meters of material you are going to use, I suppose you will take into account the auxiliary structures. Is there any way to keep them in mind, and take off your weight?
      • RGN01undefined
        RGN01
        On Slic3r PE, you can set a density for each filament type and the slicer will calculate weight of filament used to print when it slices.
        I used nominal density values and the printed object weights are generally pretty close to the estimated weights. Note that any support material is included in the printed weight.
        Richard
