    DuetWifi driving me crazy
    35
    5.0k
    • eca77undefined
      eca77
      Okay, so I got the board installed and started to do the configuration. Then the problems started. I can't seem to upload the files to the SD card over the WiFi, and the config files on the SD card are not acknowledged. When connecting through the Machine control of S3D it says that the config files are missing.
      In the beginning the files were seen and I could click edit and make changes, but when I saved the changes nothing happened. The files stayed the same as before the editing. Then things just went down hill from there. I can't upload anything to the Duet through the Web interface, just keep getting AJAX errors, and like I said although all the files are on the SD card in the right folders nothing is recognized. I have formatted the SD card and put the folders and files back on. I have then used different cards with the same results. I am I supposed to use a certain "image" that is formatted a certain way or what am I doing wrong. I hope that it isn't my board, but I doubt that. It seems like I am missing something (probably simple) that is keeping me from finishing this install.
      I accept that I won't be printing any Halloween decorations like I intended to, but I would like to do some things for my son's Birthday on the 11th!!
      Thanks in advance for any advice and help.
      • iDeveloundefined
        iDevelo
        What version of the web interface are you using? I know the beta has these issues you are explaining.
        • eca77undefined
          eca77
          • eca77undefined
            eca77
            Which one is stable?
            • iDeveloundefined
              iDevelo
              That version is fine. I'm not sure what your issue is then. I'm sure David will chime in soon.
              • eca77undefined
                eca77
                I restarted everything again, now things are half-way working again. I can control the carriage and heat things up, Just can't change any of the system files without uploading them from the computer. Also that is the only way that I can upload a file to print, to the system folder, the gcode folder doesn't seem to exist to the Duet. If I could get that working then I think it would be smoother sailing 😉
                • T3P3Tonyundefined
                  T3P3Tony administrators
                  Have a look at the card structure on the SD card do you have a /sys and /gcode folder?
                  www.duet3d.com
                    Hi, here are a couple of things to check:
                    1. If you connect Pronterface or S3D over USB and send M503, what response do you get? It should print the contents of config.g. The only folder and file you need on the SD card for that to work is sys/config.g.
                    2. Run M122 and look in the Platform Diagnostics section. After the "Free file entries" line there should be a line like this:
                    Do you see that line?
                      Our posts crossed. It sounds to me that your SD card is working OK now but you can't edit or upload files over WiFi. Is that what you are now finding? Does the System File Editor list the files in /sys, and does the GCode Files page list the files in /gcodes?
                      • eca77undefined
                        eca77
                        M503 now sends the config file, which is now working, just can't edit it from the Web interface.
                        M122 shows me what you posted (among other things).
                        • eca77undefined
                          eca77
                          The card works, I am running
                          Firmware Name:
                          RepRapFirmware for Duet WiFi
                          Firmware Version:
                          1.15e (2016-10-02)
                          WiFi Server Version:
                          1.02
                          Web Interface Version:
                          1.12
                          I went back to the 1.15e to see if it was maybe the 1.16 beta that was causing problems.
                          • eca77undefined
                            eca77
                            Here is the complete diagnostic file incase it helps:
                            READ: === Diagnostics ===
                            READ: Used output buffers: 1 of 32 (11 max)
                            READ: === Platform ===
                            READ: Memory usage:
                            READ: Program static ram used: 19284
                            READ: Dynamic ram used: 83084
                            READ: Recycled dynamic ram: 32
                            READ: Current stack ram used: 2752
                            READ: Maximum stack ram used: 4108
                            READ: Never used ram: 24564
                            READ: Last reset 00:18:26 ago, cause: external
                            READ: Error status: 0
                            READ: Bed probe heights: 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
                            READ: Free file entries: 10
                            READ: SD card 0 detected, interface speed: 20.0MBytes/sec
                            READ: SD card longest block write time: 0.0ms
                            READ: MCU temperature: min 30.9, current 32.4, max 35.7
                            READ: Supply voltage: min 1.0, current 1.0, max 1.1, under voltage events: 0, over voltage events: 0
                            READ: Slowest main loop (seconds): 0.004517; fastest: 0.000000
                            READ: === Move ===
                            READ: MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
                            READ: === Heat ===
                            READ: Bed heater = 0, chamber heater = -1
                            READ: Heater 1 is on, I-accum = 0.0
                            READ: === GCodes ===
                            READ: Move available? no
                            READ: Stack pointer: 0 of 5
                            READ: macro is idle
                            READ: http is idle
                            READ: telnet is idle
                            READ: serial is ready with "M122"
                            READ: aux is idle
                            READ: file is idle
                            READ: === Network ===
                            READ: WiFiServer is running
                            READ: SPI underruns 0, overruns 0
                            READ: === Webserver ===
                            READ: HTTP sessions: 1 of 8
                            READ: ok
                            SENT: M105
                            READ: ok T:24.7 B:22.4
                            SENT: M105
                            READ: ok T:24.8 B:22.4
                            SENT: M105
                            • eca77undefined
                              eca77
                              @dc42:
                              That is correct.
                              The system file editor now lists the /sys files, but the Gcode files are not listed in the /gcode
                              • curieosundefined
                                curieos
                                What web browser are you using?
                                She/Her
                                I work at a local 3D printing shop.
                                Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
                                • eca77undefined
                                  eca77
                                  windows edge
                                  • curieosundefined
                                    curieos
                                    Try using chrome or firefox. I haven't used windows edge but I know safari doesn't work well, and historically microsoft browsers are the worst in terms of supporting new features and frameworks.
                                    She/Her
                                    • eca77undefined
                                      eca77
                                      But I just tried Firefox, I can now edit the config files with that and it saves them. Still can't see the gcodes file….
                                      • eca77undefined
                                        eca77
                                        which is a step in the right direction, I can edit the configuration, just can't upload anything to print.
                                        • eca77undefined
                                          eca77
                                          okay, found out what the problem was. The folder was named "gcodes-ormerod", apparently that is wrong and it must be just gcodes…. would love a slap forehead emoji right now...
                                          • eca77undefined
                                            eca77
                                            can't tell my wife I have spent most of the day on this and it was a simple file name change…
