    End Print G-Code
    • dmkmedia
      dmkmedia last edited by
      whats the standard for finishing a print…. g-code wise
      i want it to go to home but turn off all heaters, motors, and fans
      • T3P3Tony
        There really is not a standard as it depends what you need then printer to do, you can put what you want in the end gcode.
        I turn off my hotend, turn down the bed (so the print releases but it's quicker to heatup for the next print) and home the printer.
        • parovoZZ
          parovoZZ last edited by
          My end script
          [c]G1 X15 Y15;
          G1 Z350; down
          M104 S0 ; turn off extruder
          M140 S0 ; turn off bed
          M106 P1 S0;
          M84 ; disable motors[/c]
          • Danal
            Danal last edited by
            Delta printer. My normal end, configured into Cura:
            [[language]]
            M104 S0      ; Extruder temp 0, don't wait
            M140 S0      ; Bed temp 0, don't wait.
            G28             ; Home, to get the head out of the way;
            G92 E1        ; Relative
            G1 E-6 F300  ; Move back
            M84 E0       ; De-energize motors
            M106 P0 S0   ;Turn off Main Board cooling fan
            My "cancel.g", run by the printer when a print is canceled (after a pause).
            [[language]]
            ; stop.g
            ; called when a print is cancelled after a pause.
            G10 P0 S0   ; Turn off the effector heater
            M106 P2 S0  ; Turn off Fan 2\.  It cools the drivers.  We'll turn it on only while printing.  DE 2018 01 28
            G28      ; Home.  DE 2018 02 01
            Note: You probably do NOT want home (G28) in either one of these on a cartesian.
