User and password for FTP???
i want to upload a file to duet, and i d'like use FTP server, i have power on….
[[language]] ; Network M550 PTLM Duet Wifi ; Set machine name M552 S1 ; Enable network M587 S"Dlink-869L.2,4" P"a1b2c3d4" I"192.168.1.50" ; Configure access point and IP addresses. You can delete this line once connected M586 P0 S1 ; Enable HTTP M586 P1 S1 ; Enable FTP M586 P2 S1
i try to connect to Duet for FTP: ftp://192.168.1.109/….. and ask me for a USER and PASSOWORD. What are?
thanks
[[language]] User = anonymous Pass = The same one as in the web interface. ```.. at least that worked for me when I tried this earlier today :-) you may be able to use 'ftp' for the username too, that's a common ftp convention.
and…. if do not remember the user/pass i have used?
Where is this?
Where is this?The password is in the M551 command in config.g.
