    Newb: Z Home routine confusion Z Max endstp switch & BLTouch Min/Probe
    • SputnikOC3d
      SputnikOC3d last edited by
      Hello Duet folks … reluctant newbie posting - so please be gentle... 1st ever printer, First ever duet wifi ... Been at this particular hurdle for 10 hrs - figure its time to ask a question for some clarification ... the more reading I do at this point is just mucking up the works and causing more confusion. Have tried to locate a similar issue and solution in docs and forum but as of yet - no luck - will continue looking but in the meantime hope someone can lend an assist.
      Prusa i3 MK2s Zaribo Clone / Cartesian printer
      X / Y Homing based off the Wiki docs - working well … X Y endstops set and working as intended [ microswitches / NC …/ X min/low / Y Max / High ]
      Read about Print Resume feature needing a Max Z endstop - so I added one into the mix … [ Microswitch / NC / Z Max/High ]
      Z Max endstop switch triggers and registers in the web GUI interface as triggered when … triggered 🙂 However; it does NOT stop/Halt Z+ axis movement.
      BL Touch Smart Probe is setup as per the Wiki Docs - 3.3v trace cut ... it is working based upon the basic test routine on the wiki docs here :
      https://duet3d.com/wiki/Connecting_a_Z_probe
      Probe deploys / lights go blue Z Probe shows [ "0" ] in GUI … Manual Z - steps via the GUI makes probe tip touches bed and triggers Web GUI registers [ "1000" ] … That is how I am so far defining it as "working" ...
      Created the deployprobe.g / retractprobe.g files as per the wiki - have yet to adjust the homez.g or homeall.g files yet ...
      At this point Im not sure which way to go to get Z homing routing configured without smashing the nozzle into the bed ... AND Im baffled currently as to why the Z Max endstop is NOT halting Z+ motion when triggered.
      Here's pertinent config.g sections :
      ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
      ; generated by RepRapFirmware Configuration Tool on Wed Jan 31 2018 09:50:41 GMT-0800 (Pacific Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X220 Y220 Z200 S0 ; Set axis maxima
      M574 X1 S1 ; Set low-end [ min ] endstops || S1 = NC / Active High S0 = NO / Active Low
      M574 Y2 Z2 S1 ; Set high-end [ max ] endstops || S1 = NC / Active High S0 = NO / Active Low
      ; Z Probe / BL Touch Smart
      M307 H3 A-1 C-1 D-1 ; Set PIN Values on Duet Board for reassignment of Heater 3 for 3.3v BL Touch [ BL Tch Specific settings ]
      M558 P5 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to [ unmodulated ??? ] || axes probe used on [ 1= in use / 0 = not in use ] || dive height || speeds
      G31 X0 Y0 Z2.5 P25 ; Set Z probe trigger value, offset and trigger height
      M557 X15:205 Y15:205 S20 ; Define mesh grid
      G31 and M557 - ripped offf str8 outta the docs - I have yet devised a plan to acquire the X Y Z offsets between the nozzle and BL Touch probe and the bed … trigger distance etc ...
      Thank you
      Steve
        Welcome to the forum!
        Have you read https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z ?
        • SputnikOC3d
          Thank you sir for the reply to my query … Yes I have seen and read thru that part ...
          Where I was mentally stuck was KNOWING the trigger distance and how to get that parameter into the configuration. What helped me move along - was finding this:
          https://duet3d.com/wiki/Test_and_calibrate_the_Z_probe
          Z is homing like a champion / BL Touch Smart is doing its thing and Im getting pretty decent repeatable trigger distances\ activations.
          Im sort of a "literal" and visual learner - yes I knew the inference to obtain that trigger height "somehow" was a known procedure but .. . In the future it may be helpful for newer folks to indicate a link to the above page from some of the Z probe/BL Touch wiki docs. Stumbled across it in a search … and its likely I missed the link in the myriad of docs I reviewed trying to sort it all ...
          It was actually on the main homepage - lol - but I was sooooo deep into the homing and BL Touch docs - I didnt go back to main wiki home for that ... guess its on me ...
          All in all - great docs/wiki ... Very pleased with my Duet wifi purchase and the documentation thereof ... Thanks for all you do !
          Now its off to Mesh Bed Leveling 🙂
          • SputnikOC3d
            Alrighty then … moved passed some my issues .. but a few small nagging items in this vain - left to resolve.
            Z Max endstop with a Z probe ... Z max endstop registers in the software as working Active High / NC switch ... light on z axis clicks OFF when switch is activated ... however; when testing by doing a long z+ move ... say 100+ off the z home position, triggering the switch .... do NOT stop the Z+ axis movement... I suspect my config.g settings for both a Z probe AND a Max endstop switch or incompatible - but Im not finding docs on how to run both.
            Z probe as min / low - endstop ? How...
            Also, Im finding nothing useable in the area of how to determine the x/y horiz offsets between PROBE and Nozzle
