Duet wifi on the go
Hello forum,
I have the duet connected at home in the wifi and that works well.
But if I'm on the go with the printer there is no wifi available.
How can I connect the duet with my ipad to control the printer? -
You have two easy options.
setup the Duet as a WiFi access point:
Configure the Duet's SSID and password using M587
https://duet3d.com/wiki/G-code#M589:_Configure_access_point_parameters
Then use M552 S2 to put it in access point mode (you need to start with WiFi disabled M552 S0).
https://duet3d.com/wiki/G-code#M552:_Set_IP_address.2C_enable.2Fdisable_network_interface -
use a mobile phone in "portable hotspot" mode to create a WiFi network that both the Duet and the iPad can connect to.
To switch between "home wifi" and "on the go" i have to connect with USB to disable wifi (M552 S0) and start accesspoint (M552 S2).
Is there a way to switch it without a USB Connection? -
Is there a way to switch it without a USB Connection?You could do it using a PanelDue, or connect a push button to a spare endstop input and set up a trigger macro using M580.
