Smart Effector Not Triggering
  • my smart effector is not triggering. on power up it flashes twice as it should, i have checked the wiring and i have continuity on all four wires, and i have also removed my nimble from it.
    anything else i should be checking?
    ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
    M665 R106.3 L215.82 B102 H260 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
    M208 Z-0.1 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S0 ; Set active low endstops
    M558 P5 R0.4 F1000 ; Set Z probe type to effector, the axes for which it is used and the dive height + speeds
    G31 P100 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
    M557 R85 S20 ; Define mesh grid
    M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
    M92 X100 Y100 Z100 E2400 ; Set steps per mm
    M566 X36000 Y36000 Z36000 E36 ; Set maximum instantaneous speed changes (mm/min)
    M203 X1080000 Y1080000 Z1080000 E1200 ; Set maximum speeds (mm/min)
    M201 X3000 Y3000 Z3000 E120 ; Set accelerations (mm/s^2)
    M906 X1500 Y1500 Z1500 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    ;M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
    ;M301 H1 S1.00 P10 I0.1 D200 T0.4 W180 B30
    M305 P0 X201 ; Set thermistor bed
    M305 P1 X200 ; Set thermistor hotend
    M563 P0 D0 H1 ; Define tool 0
    M550 PMagKossel ; Set machine name
    M552 S1 ; Enable network
    M587 S"NETGEAR81" P"o8346969" I192.168.1.101 J192.168.1.254 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    Does the green led flash when you tap the nozzle upwards? If it doesn't, ask for the effector to be replaced.
  • it does not. i will contact filastruder then. thanks.
