12v fan on 24v duet
Hello
My duet is powered 24v and i want to use 12v fan. İs it enough to use with resistor an will it damage the fan after some period of time? Or the board? İ will uei on allways on fans slot
Our recommendation is to use 24V fans - they don't cost much on eBay.
Alternatively, you can do as I've done, and use a buck converter between the 24v psu to feed a 12v supply into the V_fan terminal of the fan jumper block. This lets the duet and everything else function off the main 24v supply and the fans all use 12v.
Hello
My duet is powered 24v and i want to use 12v fan. İs it enough to use with resistor an will it damage the fan after some period of time? Or the board? İ will uei on allways on fans slotI'm using a resistor. An accurate calculation is required by Ohm's law. For blowing two fans 12V. It's OK.
There are lots of threads on fans.
Easiest options:- use all 24v fans if you have 24v PSU
- use all 5V fans if you can
Or search for buck converter/secondary PSU options.
