Power relay
Okay so if I am going to use a module like this, to control mains on/off (with a permanent 5v supply to duet):
Which takes care of the isolation and flyback diode etc.. But it needs +5v to trigger, what is the best way to go about it? My reading of the wiki suggests PS_ON pin is grounded when M80 is sent?
Are you sure that relay board has isolation? I don't see an optical isolator on it.
Okay maybe not that one but there are units for a few £'s more which do.
Regardless - how would you advise connecting it?
How about this one?
That one has a 4-pin device on it that is probably an opto isolator.
It's a bit of a different level of investment if you don't have a system up and running, but I have the printer on a z-wave plug which also monitors power consumption (bit of an eye opener) simplifies setup a fair bit.
Sure thats one way of doing it and I think asking David to consider some sort of interface to radio switched plugs/alexa etc. could be a great addition. But I'm just considering simple M80 for on and M81 for off setup. I have 3 machines running duet board now so a simple solution is what I'm after. I have a power monitor running to the bench for all my printers it is interesting I agree.
If powering the duet from external 5v should we use the 5v & GND pins in the PS_ON header? Or can plugging in a usb charger/adaptor to the usb port suffice long term?
You can feed power via the USB port or the external 5V connector (the one with the PS_ON pin), it makes no difference.
Thank you.
Share the results and diagrams if works. I'm thinking on use a similirar relay board with ps_on pins of the duet to fire the camera button and makes timelapses
I'm still none the wiser as to how best to connect it. It seems some of these relay modules can accept a high or low signal, so set to low, I would expect you can ground the IN pin on the relay to the PS_ON pin on the duet to trigger it. For those relay modules which only accept a high signal then if PS_ON goes to ground when M80 is sent, I think it might be best to use something like a logic inverter to reverse the signal. https://www.ebay.co.uk/itm/LOGIC-SINGLE-INVERTER-GATE-5SC70-Part-SN74LVC1GU04DCKT/351615798176?epid=1339373369&hash=item51ddef4ba0:g:QM8AAOxy8HlSa77O
If you choose a relay module with an optically isolated input, then it will hopefully have + and - control input terminals separate from the power supply terminals. In which case you can connect the input terminals to +3.3V or +3V and PS_ON.
To use it as a camera trigger, I need to execute m80 and followed by m81. What interval would I have if I put them one below the other in the gcode?
More than a microsecond, but possibly less than a millisecond.
I can't tell if that is a joke or not. I will read about gcode waits and try to trigger the camera without the duet first
Okay so I've settled on this one:
So to make this work, I would hook up +5v from the duet to both VCC and CH1 pins, then GND to PS_ON?
No. Please post a photo of the back of the board with better lighting and focus, so that I can see the PCB traces clearly.
The traces still are not very clear. But I think that CH1 and GND are the input signal, connected to the input of the opto coupler through a series resistor, while VCC and RGND provide power to the relay. If that's the case, connect VCC to +5V and RGND to ground. Connect GND to the Duet PS_ON output, and connect CH1 to either +5V or +3.3V.
Okay thanks David. I'll have a play with it on the bench before connecting it to a duet board.
Okay so it did end up working as I had suggested originally, I spoke to the vendor who said to ignore RGND and use VCC, GND, CH1 pins. In fact it did not seem to matter whether PS_ON is connected to GND or RGND so I presume they are tied. So connecting VCC and CH1 tied to +5v on expansion connector and then GND to PS_ON switches the relay on M80, and off on M81.
Nice bright LED too if you are going to put it under a cover of some sort it will shine through. Mine is going to live under the PSU end cover which keeps small fingers off the 240v wiring.
Why dont connect the 5v/CH1 to the 5v on ps_on header?
Because and it took me a few minutes to work this out yesterday, its a 5v input pin, not 5v output! There is a diode on it.
Ok ok. Then 5v/CH1 go in any 5v output and gnd to ps_on.
By any I presume it will have to be either the 5v output from your 5v power source for the duet board, or from the board itself with the ext-5v jumper attached. Otherwise the relay wouldn't have a ground.
