    Cancel script….
    • peirofundefined
      peirof
      It was to see how the following could be done:
      When I have to cancel a print job, for the moment more often than I would like, I do it by turning off the printer.
      I know it's not the best way. I had planned to do it with scripts, I see two options:
      TO CANCEL AN IMPRESSION:
      a) - That when a printout is canceled by DWC, a script is executed, and in that Script it includes the orders that I indicate below. Stop.g, it is executed only when the printing is finished, or also when it is canceled? (If it is executed when it is canceled it could be the solution)
      or
      b) - Execute a Script, cancel the printing and execute certain gcodes
      I thought to include the following ones. What is your opinion? Add / Remove or change order something?
      [[language]]
      G1 E-40 F100; Retract filament
      G28; Homing
      M140 S-273.15; bed switched off
      M104 S0; heater switched off
      • peirofundefined
        peirof
        mmm…..
        this resolves my dudes... contents of [c]stop.g[/c]
        [[language]]
        ; stop.g
        ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
        ; generated by RepRapFirmware Configuration Tool on Sun Jan 21 2018 07:57:47 GMT+0100 (Hora estándar romance)
        • DADIYundefined
          DADIY
          @peirof:
          or
          [[language]]
          G28; Homing
          Check out cancel.g in the documenation, I think this file would do what you want.
          https://www.duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Pause.2C_resume_and_cancel_files
            The usual way to cancel a print is to press the Pause button in DWC or on PanelDue, then the Cancel button. When you do that, macro file sys/cancel.g is run, if it exists.
