    Stepper settings - Stuttering motors
    1633
    • msn85
      msn85 last edited by
      Hello, i am sure this question has been asked many times before. I have previously had great success upgrading my delta printer to a duet board. it was some tweaking in the config file to get it running, but now its running great. So i wanted to upgrade my chinese cartesian to a duet also, but I am going mad tryin to get the steppers to stop stuttering. I have tried to make a new config file multiple times, but i dont see any constistency in changing values and when the motors stutters. Right now my X and Y seems ok, but my Z motors keep making noise, stutter and not going where they are supposed to. Checked for voltage drop, changed to better sd card. I am not sure what settings i am supposed to have on current on the motors, since i cant find the data sheet for my motors. (SL42STH40-1504A). Anyone have a pointer where to look?
      ; Configuration file for Duet Ethernet (firmware version 1.17 to 1.19)
      ; generated by RepRapFirmware Configuration Tool on Sun Jan 07 2018 18:24:15 GMT+0100 (W. Europe Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P5 ; Set firmware compatibility to look like Repetier
      M208 X250 Y250 Z400 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S1 ; Set active high endstops
      M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:235 Y15:235 S20 ; Define mesh grid
      M584 X0 Y1 Z2:4 ;Set driver map
      M350 X8 Y8 Z8 E8 I1 ; Configure microstepping with interpolation
      M92 X102.5 Y102.5 Z400 E420 ; Set steps per mm
      M566 X17 Y17 Z0.4 E4 ; Set maximum instantaneous speed changes (mm/min)
      M203 X1000 Y1000 Z4 E17 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z4 E750 ; Set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1500 E1500 I50 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M563 P0 D0 H1 ; Define tool 0
      M550 PMy printer ; Set machine name
      M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
      M552 P192.168.1.20 S1 ; Enable network and set IP address
      M553 P255.255.255.0 ; Set netmask
      M554 P192.168.1.1 ; Set gateway
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      • msn85
        Also, when changing config file on the web interface, the board reboots. but is all changes active or do i have to power off also?
          Possible causes of Z motor stuttering include:
          • Z acceleration or speed set too high. Try reducing them to low values. [Edit: you have already done that.]
          • Insufficient motor current. Try 1000mA. If the motors get hot, reduce it. If they are stone cold, you could increase it.
          • Excessive friction or binding of the Z mechanics. Do the leadscrews etc. turn freely by hand?
          • Faulty Z driver. Connect the Z motor to the E1 motor output, use M584 Z4 E3 to remap Z to the E1 motor output, use M906 after that to set the current, then see if it works any better.
          @msn85:
          That is sufficient to activate the changes. You do not need to power off.
            PS the 1504 bit of the part number suggests a rating of 1.5A per phase.
            • msn85
              ok, thank you for the answer. i have set the current to 1500mA in the config. I have two z motors. First i tried running them in series, did not get desired result, so now i am trying running one of the z motors on E1. Sometimes the motors seem fine for a couple of seconds when jogging, then they start again.
              • msn85
                When running two Z motors on different drivers, the acc and current settings apply to both motors if they are mapped as Z?
                  @msn85:
                  Yes, as long as you use M906 to set the current after using M584 to set the mapping.
                  • toshi
                    toshi last edited by
                    Hi, I have a similar issue with my noisy dual Z motors , remaped on E1 stepper make the motors quiet but also using only 1 motor on Z solved it..
                    All the motors on my printer are the same (42BYGH4812AA), can handle 1,2A and are set to 800mA on XY and are quiet. On dual Z, I try from 800 to 2600mA and nothing change and in single Z it's nice from 800 to 1200mA.
                    I don't know if I clear, but do you have an idea why it's like this ?
                    Thanks
                      Those motors are relatively low current and high inductance. So if you are using only a 12V supply then there may be insufficient drive voltage to move 2 of them in series other than at low speeds. See the motor calculator at reprapfirmware.org. For those motors, connecting them in parallel may work better than connecting them in series.
                      • Kezat
                        Kezat last edited by
                        Couple things jump out at me with your config.
                        Interpolation only works if you set the microstepping to 16X, your running a coarse 8x atm.
                        The XY values look a bit strange here, try setting them to a more normal 200-500 range perhaps? Maybe 100 for Z?
                        A bit slow for the X and Y (16.6mm/s) perhaps? Z is crazy slow at 0.06mm/s not sure how well its going to behave that slow. E is also slow, with direct drive your going to want it much much faster at least the 1500 range.
                        Perhaps your config looks like that because your troubleshooting but if not a more normal baseline might rule out the easy stuff.
