Houston… We(I) have a problem....
  • Well…this is embarrassing ...
    So far, I used Duet with a laptop, I was adjusting it ... and now that I think I have it all, I'm going to install the Due + LCD Panel 5 ", if it was not because I can not find the cable that connects the Duet board to the Panel Due ... I know, it's my fault, but ... I can not install the Due + LCD Panel 5 "...
    I need your help...
    How can I get another one?
    Can it be manufactured? (Any indication?)
    Here are some options:
    1. Ask your your PanelDue supplier if you can buy another cable.
    2. Make up a 4-way cable with a 4-pin Molex KK connector at each end, and the order of the wires reversed between the two ends. You may have some 4-pin KK connectors left over from the ones that came with your Duet.
    3. If the PanelDue is version 3 and the Duet is version 1.02 or later and the distance between the two is 300mm or less, use a 10-way ribbon cable. This is the easiest cable to make, and you can also buy it ready made on eBay etc.
Locked
