G32 mes leveling ? am i doing it right?
here is a video I speed up ( it takes 6 min to level my bed what am I doing wrong) I have used G29 on every printer I have but haven't figured out how to use it on the duet.
questions I have are
do I put G32 in the start Gcode? I read that the mess is stored how can I use that?
is G32 the proper way to level my bed? is there a better way please advise.
I read that mesh leveling this way only stores 5 points so am I doing it wrong?
https://www.youtube.com/watch?v=xJCS6M6FDxM&feature=youtu.be
and here is my bed.g
; bed.g
; generated by RepRapFirmware Configuration Tool on Fri Feb 16 2018 22:07:26 GMT-0700 (Mountain Standard Time)
G28 ; home all axes
M98 Pdeployprobe.gG30 P0 X25 Y25 H0 Z-99999
G30 P0 X125 Y250 H0 Z-99999
G30 P0 X325 Y350 H0 Z-99999
G30 P0 X125 Y500 H0 Z-99999
G30 P1 X25 Y705 H0 Z-99999
G30 P1 X250 Y605 H0 Z-99999
G30 P1 X450 Y555 H0 Z-99999
G30 P1 X600 Y605 H0 Z-99999
G30 P2 X885 Y705 H0 Z-99999
G30 P2 X785 Y500 H0 Z-99999
G30 P2 X685 Y400 H0 Z-99999
G30 P2 X785 Y250 H0 Z-99999
G30 P3 X885 Y15 H0 Z-99999
G30 P3 X600 Y115 H0 Z-99999
G30 P3 X400 Y215 H0 Z-99999
G30 P3 X250 Y115 H0 Z-99999
G30 P4 X450 Y375 H0 Z-99999 S
M98 Pretractprobe.g -
You are having multiple P0, P1, P2, P3 so they are overwriting each other
You should have P0 to P16 for your 17 points probe. -
I've always thought 5 points were plenty.
As a matter of fact and I hope I am not misquoting DC42, but I think I read where he said especially with a glass bed that probing just the 4 corners was enough.I have a 300mmx300mm glass bed and I use 5 and it has been perfectly adequate for me. And If I am doing it wrong I didn't know any better.
It only take me about 30 seconds where as you have quite a wait for yours to finish.I probe my bed in an "M" pattern.
Here is my gcode for what it's worth.[[language]] ; Probe the bed at 5 points G30 P0 X15 Y15 H0 Z-99999 G30 P1 X15 Y255 H0 Z-99999 G30 P1 X150 Y150 H0 Z-99999 G30 P2 X285 Y255 H0 Z-99999 G30 P3 X285 Y15 H0 Z-99999 S
You should have P0 to P16 for your 17 points probe.Jackal you just pointed out something I never noticed. I have conflicting points too.
Gonna fix that right now.
Thanks!~ -
Thanks I was wondering what that error ment.
And this is a 760x915 plexiglass so I want to probe more points to get a good mesh.
ok that many points don't work i need to get G29 working
