    PanelDue Frozen
    • Adamfilipundefined
      Adamfilip
      Ive noticed that if i start a print job, the Paneldue screen seems frozen and wont update while its heating up, then it will go back to normal.
      the web interface works fine.. updating the entire time its warming up.
      • StephenRCundefined
        StephenRC
        Bug work around is to add G4 P2000 before the M190.
        • SimonRaffertyundefined
          SimonRafferty
          I've found the G4 P2000 only works sometimes - not always. Not figured out when, but it's not a big problem in the scheme of things.
          Si
          • DuetUserundefined
            DuetUser
            Do you have latest firmware and new panelDue? I had hangups on PanelDue 1.1 and 1.12 firmware, it happened sometimes while 'overclicking', now I have 1.15 and so far it's ok, not too much testing behind though.
            peter
              Adamfilip
              This is what im running
              Firmware Name: RepRapFirmware for Duet WiFi
              Firmware Electronics: Duet WiFi 1.0
              Firmware Version: 1.16rc2 (2016-11-05)
              WiFi Server Version: 1.02
              Web Interface Version: 1.13-rc2
              dont recall what the paneldue is running
