    First ever print , problem with X axis
    1
    299
    • peter247
      peter247 last edited by
      Just tried my first test print with my home build / design printer , using cura .
      Not sure if its a config setting or if its the gcode generated by cura , where to start ?
      My problem is when I print the gcode it says X axis is 30 and does not increase the X layers , printing each layer on top of each other but saying it`s still layer 1.
      I have both cura / duet wifi set to marlin and all axis work , home etc , so it looks to be configured right before the test print
      Any ideas !!!!
      Thanks in advance Peter A
      I THINK I`VE FOUND THE PROBLEM , the z offset was set to x30
