    Resume print after color change in vase mode issue
    1.8k
    • mrac1undefined
      mrac1
      I'm using the macro below for color changes with S3D on my delta. Works perfect, except in vase mode. In vase mode, after the filament is changed, the effector moves realy slow back to the print and don't starts at the correct z-height. Where did i make a mistake?
      M400 ; Wait for moves to complete
      G1 E-2 F3600 ; retract 2mm of filament
      G91 ; relative positioning
      G1 Z50 F3000 ; lift Z by 50mm
      G90 ; absolute positioning
      G1 X0 Y-160 F6000 ; Move nozzle to the front
      G92 E0; Reset extruder
      G1 E-30 F300 ; Retract 20mm of filament at 300mm/min
      G1 E-200 F3000 ; Retract 480mm of filament at 3000mm/min
      G92 E0; Reset extruder again
      M291 P"Insert filament, klick OK when ready" R"Color change" S3 T0 ; Display message
      G92 E0; reset extruder
      G1 E25 F600 ; Feed 25mm of filament at 600mm/min
      G1 E125 F3000 ; Feed 125mm of filament at 3000mm/min
      G1 E100 F300 ; Feed 100mm of filament at 300mm/min
      G4 P1000 ; Wait one second
      G92 E0; reset extruder again
      M291 P"Clean the nozzle and press OK" R"Color change" S3 T0 ; Display message
      G1 R1 Z50 F6000 ; go to 50mm above position of the last print move
      G1 R1 ; go back to the last print move
      M83 ; relative extruder moves
        How do you invoke that macro?
        • mrac1undefined
          mrac1
          Within the post processing in S3D, and this command:
          {REPLACE "; process color2" "M98 P/macros/color change"}
          {REPLACE "; process color3" "M98 P/macros/color change"}
          I rename the processes for the color change accordingly
            I think the problem is no pause command is being issued, so the paused coordinates needed by the G1 R1 commands at the end are undefined.
            • mrac1undefined
              mrac1
              Now I've tried it with M226, but this doesn't solve the problem. But I've seen, the z-height ist correct, it's just to slow and the filament is ozzing out while traveling (takes about 5sec).
              The weird thing is, without vase mode, it works really nice.
                Without vase mode, my guess is that the slicer is inserting a move to the correct XYZ position immediately after that comment you are replacing and the associated tool change.
                • mrac1undefined
                  mrac1
                  This is the gcode in normal mode:
                  G1 X-8.710 Y11.054 E0.0291
                  G1 X-9.300 Y10.635 E0.0291
                  G1 X-9.623 Y10.357 E0.0171
                  G1 X-9.850 Y10.161 F1019
                  G1 E-1.6000 F2100
                  G1 Z5.250 F15000
                  ; layer 21, Z = 5.200
                  M104 S215 T0
                  M140 S60
                  M106 S224
                  G1 X-9.855 Y10.156 F18000
                  G1 Z5.200 F15000
                  G1 E1.6000 F2100
                  G1 X-10.158 Y9.854 E0.0172 F1019
                  G1 X-10.399 Y9.587 E0.0144
                  G1 X-10.808 Y9.069 E0.0265
                  and in vase mode:
                  G1 X-8.710 Y11.054 Z4.944 E0.0291
                  G1 X-9.300 Y10.635 Z4.946 E0.0291
                  G1 X-9.850 Y10.161 Z4.948 E0.0291
                  M104 S215 T0
                  M140 S60
                  M106 S224
                  G1 X-10.158 Y9.854 Z4.950 E0.0175 F1019
                  G1 X-10.399 Y9.587 Z4.951 E0.0144
                  G1 X-10.808 Y9.069 Z4.952 E0.0265
                  Maybe you find something what's going wrong.
                    So in normal mode you have this:
                    M104 S215 T0
                    M140 S60
                    M106 S224
                    G1 Z5.200 F15000
                    G1 E1.6000 F2100
                    After the tool change it sets XY and then Z to the required position before it does any extrusion. In vase mode it does this:
                    M104 S215 T0
                    M140 S60
                    M106 S224
                    It doesn't reset the position before extruding again.
                    • mrac1undefined
                      mrac1
                      In normal mode, it's the startpoint of the next layer, in vase mode, there ist no startpoint, because there ist no endpoint from the last layer. Any suggestions how I could solve this?
                        I am implementing the G60 command in firmware 1.21RC3. I think using this will solve your problem.
                        • mrac1undefined
                          mrac1
                          Thank you very much David!
                          • mrac1undefined
                            mrac1
                            Unfortunately, nothing has changed. G60 S0 saves the current position and with G1 R0 the nozzle is going back to the saved position. But I do not think that's the problem. The position is simply approached very slowly. And as I said, the strange thing is, it only happens in vase mode. Otherwise the movement is normal fast.
                            From these lines, it is slow:
                            Then it goes on normally.
                              G1 R0 does nothing at all because only axes that are mentioned are moved. Use these lines instead:
                              G1 R0 X0 Y0 Z50 F6000
                              G1 R0 X0 Y0 Z0
                              I don't know why you use Z50, I use Z2 for this sort of thing.
                              • mrac1undefined
                                mrac1
                                The 50mm are only for the test so that there is more room for the extruded filament when changing. I'll try your suggestion later, I'm curious if this affects the travel speed.
                                • mrac1undefined
                                  mrac1
                                  You where right! šŸ™‚ Travel speed is now fast again! Thank you!
