    Guide for Delta calibration/mesh leveling needed
    • pabomanundefined
      paboman
      hi there,
      Im new to duet electronics, i just finished to setup the delta but I found the provided online documentation very dispersive, is there any clear guide step by step for calibrating mesh leveling a delta from the beginning ?
      where can I also find a list of all supported command by the duet in the documentation ?
        See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer for calibration. A well-built delta shouldn't need mesh compensation once you have calibrated it, but if yours does then see https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation.
        • T3P3Tonyundefined
          T3P3Tony administrators
          @paboman:
          All the supported Gcodes are here:
          https://duet3d.dozuki.com/Wiki/Gcode
          www.duet3d.com
