Silly newbie can't get wifi up and running!
  • Hi guys,
    I'm sure I'm missing something simple but I can't seem to figure out what.
    I'm using a mac, so have connected via terminal. I have verified firmware is 1.19.2 and ascertained that the wifi module is enabled and it returns idle status.
    I enter the command
    M587 S”NETGEAR13” P”wifipassword”
    (but obviously with my actual password) expecting it to then confirm the connection and return the IP address…. but instead I get
    "Error: G-Code buffer 'serial' length overflow"
    Further, when I first connect this is the return:
    RepRapFirmware for Duet WiFi Version 1.19.2 dated 2017-09-01
    Executing config.g…Error: G-Code buffer 'daemon' length overflow
    Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicteError: G-Code buffer 'serial' length overflow
    which strikes me as slightly odd.
    I have tried a few times now, got no idea what I'm doing wrong. Any guidance? Power is purely through the USB as per the instructions if that is relevant.
    Cheers
    Not silly at all! I guess you have a very long password. The buffer size was increased in firmware 1.20 because someone else previously reported this problem with 1.19. So I suggest you upgrade main firmware to 1.20 first.
  • Thank you, I am now up and running 🙂
    Looking forward to getting printing with it tomorrow now!
  • Hi,
    I've got the same problem with a brand new card that arrived today.
    Just connected it to my Mac and have started the connection guide. I connect my Mac up and run the screen command boom I just get these errors:
    [[language]]
        Executing config.g...Error: G-Code buffer 'daemon' length overflow
                                                            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicteError: Temperature reading fault on heater 1: sensor open circuit
    What should I do now?
  • Spoke too soon…
    I ignored the error and typed the commands from the guide and it worked..
