    Call end.g when sdcard file completes
    Firmware wishlist
    • TickTockundefined
      TickTock
      Although slicers will automatically add pre and post code, I would like the firmware to automatically call a macro upon completion of the print.
        You can create a file called end.g and then call it with the M98 command from your slicer end code.
        https://duet3d.dozuki.com/Wiki/GCode#Section_M98_Call_Macro_Subprogram
        So add M98 end.g to the slicer end code.
        Then add whatever you want to end.g
          It already calls stop.g if your file ends with command M0.
          • TickTockundefined
            TickTock
            Thanks. And thanks. I suspected there must be already a solution.
