    Delta 200
    My Duet controlled machine
    1.1k
    • jerry426undefined
      jerry426
      Here's mine:
      https://goo.gl/photos/UQNNqLhQ3m899gse9
      In the group photo it is the small black/red one. The other 3 all have Duet 0.8.5 and I predict they will all be running Duet WiFi soon just because it makes FAR less noise.
      • T3P3Tonyundefined
        T3P3Tony administrators
        Nice!
        (off topic) how are you finding the split bottom corners for frame assembly? Is the advantage just that they are easier to print?
        Cheers
        Tony
        www.duet3d.com
        • jerry426undefined
          jerry426
          @T3P3Tony:
          Nice!
          Cheers
          Tony
          Thanks.
          I was simply wanting to double up on the bottom structure for what little extra rigidity it would provide and to give me plenty of space in there for power supply and other components - so you guessed correctly about being somewhat easier - I only need to print a single part design for all 9 corner pieces. As you can see in the photos, I downsized the lower section of my new 200mm delta to use 20x20 and designed the 20mm corner piece for it. As far as assembly goes, it is just enough of a challenge to get the two lower sections to be perfectly parallel to each other that I am going to design an all-in-one corner which will make the bottom of the printer easier to assemble.
