    Pi Zero Power?
    1134
    • zBeeble
      zBeeble last edited by
      My power supply only outputs 12V. I'd like to have a Pi zero-W run as a web cam. Can I pull that much power from the Duet Wifi? Where?
      • tjb1
        tjb1 last edited by
        There are 2 places on the Duet, in the expansion connector and the PanelDue connector -
        Full image here - https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/wBEk2ppaxAUNgkMH.huge
          I installed a USB port power plug into my PSU case. It also shows the PSU voltage for fun.
          https://www.amazon.ca/gp/product/B06XP28Q1L/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
          It must have a buck converter of some sort to drop it down to USB voltages.
          • T3P3Tony
            How much power does the pi zero+cam take at 5V? Do you have a PanelDue connected and if so which one?
            • zBeeble
              Doing a quick survey, with the camera running and the chip compressing 1080p, it draws 240mA at 5V.
              • coolice
                coolice last edited by
                Hey.
                Most Raspberry Pi's, according to the online information, need a good 1.5 to 2 amps power supply to run without issues.
                So I'd look to give it a good power source external to the Duet.
                • Mike
                  Mike last edited by
                  Zero W will not draw more than 500 mA barring very specific circumstances.
                  • zBeeble
                    That seems to be my reading too. The zeroW is a single (not quad) core with 512M (not more as most larger pi)
                    Going back to my situation, I do have a 7" screen attached to my Duet Wifi. What would be the limit on 5V power draw from the Duet?
                    I'd like to have a zeroW webcam and an IR z-endstop. I don't know if the latter draws 5V, but I suspect it might.
                    • Mike
                      Mike last edited by
                      I think David answered that here: https://www.duet3d.com/forum/thread.php?id=4146#p36434. You should be fine, around 1 A for Duet+PanelDue and 0.5 A for Raspi Zero W puts you still 0.5 A below the limit of the 5V regulator. I'd still probably go with a small buck converter. Just to be on the safe side in case something goes really wrong.
                      • zBeeble
                        So you're saying: pull the power from the 12V … but with a converter.
                        Can you point me at a cheap solution for that? Buyapi.ca only has a $30 part for this purpose.
