    Heater problem
    • janjohundefined
      janjoh
      Hello!
      Second thread, and more issues. Duet Wifi in a Delta.
      I cannot get my hotend to heat up, it is actually worse that that, I do not seem to get any voltage on my E0/E1 outputs.
      I disconnected my cables, and attached my oscilloscope to the E0 (and for that matter E1) output. I turned the heater on but i still get no voltage on the E0 / E1
      Is there any setting i may have missed. Seeming i messed up my endstops earlier, it is far from unlikely.
      if i heat my hotend with my hand, I can see a slow rise in the readout for Tool0 which is on Heater 1.
      If i measure resistanse over my heater cable (all the way from the end that was connected to myu Duet i get 5 ohms with the 6-pin connector of the Smart Effector connected, and "infinite" if i unplug the 6-pin connector. So, that seem to be reasonable.
      The heater indicator led does turn on on the Duet Wifi, but not on the smart effector if i have it connected.
      If i disconnect the heater cables from the Duet Wifi and power it from my lab supply it heats up nicely, and the amber led on the smart effector turns on.
      [c]; Configuration file for Duet WiFi (firmware version 1.20 or newer)
      ; generated by RepRapFirmware Configuration Tool on Sat Mar 10 2018 00:14:59 GMT+0100 (W. Europe Standard Time)
      M665 R225 L360.2 B125 H430 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M550 PFull Metal Delta ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X80 Y80 Z80 E663 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
      M557 R125 S20 ; Define mesh grid
      M563 P0 D0 H1 ; Define tool 0
      ; Custom settings are not configured[/c]
      • janjohundefined
        janjoh
        Let me answer my own question and give you a laugh…. This apparently happens when you do not notice your PSU being turned off and you still have USB power.
        Yeah.. I did do that.
