Mini height sensor board
  • Hi. I bought the Mini height sensor board, but I have trouble setting the trigger height. The LEDs flash 4 times at first boot up and read the P1 value when the sensor is close to the table, but the head gets 3-4 mm high from the trays and I set it to be 1 mm between the card and the nozzle height what could be the problem?
    I'm sorry, I don't understand your post. Please explain what you mean by "the head gets 3-4 mm high from the trays and I set it to be 1 mm between the card and the nozzle height".
