    Instruction for custom splash screen
    Firmware installation
    1935
    • paboman
      paboman last edited by
      I saw that is possible to create personalized splash screen but I cant find any information on how to do that.
      Any help will be greatly appreciated
        I haven't yet got round to writing the instructions for that. Basically:
        1. Export your image file in 24-bit .bmp format with exactly the same height and width in pixels as the TFT panel;
        2. Run bmp2c-escher3d.exe on the file using options -b -c to generate a compressed version of it;
        3. Concatenate it on to the end of the -nologo version of the PanelDue firmware binary.
          Takes me back to hacking the Windows 98 startup screen.
          • ampex_fhm
            ampex_fhm last edited by
            just to be sure, binary concatenation has to be used right?
            the matching windows command I found to do that is:
            [[language]]
            copy /b file1+file2+file3 targetfile
              Yes, I use copy /b to do this.
                I have added instructions to the readme file at https://github.com/dc42/PanelDueFirmware.
                • timcurtis67
                  timcurtis67 last edited by
                  Sweet! Thank you David.
                  I have a 7" PanelDue with the 256kb memory chip on a V2 board. Is there a V2 7" no logo.bin version that I can down load or do I have to build my own?
                  I mean a PanelDue-v2-7.0-nologo.bin version?
                    All the -v2- files are without logo.
                    • timcurtis67
                      @dc42:
                      I missed that before. So any for a V2 board versions will have to be built from scratch.
                        No, you can use the -v2- files as they are.
                        • mrac1
                          mrac1 last edited by
                          Hi David, there is a little typo in the readme.md:
                          "Run this Windows command to compress the image: bmp2c-escher3d.exe myimage.bmp myimage.bin /b /c"
                          instead of:
                          "Run this Windows command to compress the image: bmp2c-escher3d.exe myimage.bmp myimage.bin -b -c"
                            Thanks, I've corrected it.
                            • paboman
                              Sorry how to run copy /b file1+file2 targetfile ?
                              Im using Windows + R to open the command terminal then write g:\ copy /b file1+file2 targetfile
                              because my files are in both in drive G but when hitting enter it only open the G:\ folder
                              • paboman
                                Ok got it, I have to use CMD terminal, navigate to the G drive and then execute the command 😄
