    Mounting case for DC42's IR-Probe on Thingiverse
    Example setups and prints
    1.6k
    • Pumluxundefined
      Pumlux
      Hi all,
      I found no better place to raise this thread.
      On thingiverse is a small mounting case for the IR-probe from David, it includes a lock mechanisim to prevent loosening of the cable from the probe.
      May be this is interessting for some people.
      Mounting case for DC42's IR-probe on Thingiverse
      Regards
      Pumlux
      Using a own build of a Mendel Max , Duet Wifi, Bed 8 mm Aluminium PEI 500 x 280 x 400 230 V 850 W, original E3D Chimera hotend with bowden length 700 mm, since short time with a BL-Touch, Steppers : mostly Nema 17 and one Nema 23 for Y-axis
      • Merlinundefined
        Merlin
        Printed and fitted this little case and I am in no doubt it will save me from smashing up any more IR sensors.
        (I always keep a spare because I have broken so many).
        Thanks
        • ShadowXundefined
          ShadowX
          If you are handy with a soldering iron, it is best to directly solder the wires to the sensor and connect it to a locking connector a few inches away. You have to remove the existing connector on the IR sensor in order to thru mount the wires into the connector plated thru holes. Once you connect to your harness, put kapton tape around the mating connectors to prevent accidental disconnects.
          If you are not handy, I suggest adding some flexible but strong glue like E6000 around the joint to keep it in place. I wouldn't use a glue gun since it is not as strong as E6000.
